Fly Boomer Posted October 5 Report Posted October 5 Question for any of you who have ever flown behind a KAP-150. I'm creating a PFT (Pre-Flight Test) checklist from the Pilot's Guide, and getting behavior that I don't understand. K-model sitting in the hangar. GPU plugged in; Master on; Radio Master on; Elevator Trim on; Standby Vacuum Pump on; GNS-430 on; give the gyros a few minutes to stabilize. Tap the Test button, all annunciators on both the KC-191 and KAS-297b light up; flashes and beeps five times; AP annunciator blinks; Trim annunciator goes off. AFAIK all these automatic gyrations are expected. MET (Manual Electric Trim) on yoke: Left side up and down, wheel doesn't move BUT I can't overpower the MET using the wheel. Right side up and down, wheel doesn't move, and turns freely. Wheel does not turn when holding AP DIS/TRM INT button on yoke. Again, AFAIK all is well (except for being able to overpower the MET when left side of trim button is used). Turn on AP ENG button on KC-191 (pitch hold/roll level mode), and box the controls to assure I can overpower autopilot -- all okay. Add HDG on the KC-191, and the yoke turns left and right to follow the Heading bug on the KI-525 HSI -- all okay. Now, after about 5 seconds, the trim wheel starts creeping slowly nose up. Takes at least a minute to get all the way nose up. I'm not sure what it's headed toward, but in flight this would not work. Also, if I use the Up/Dn rocker on the KC-191, nothing happens for 3-5 seconds, and then the trim starts to move. If I take my finger off the rocker, the trim CONTINUES for at least another five seconds, or until the trim is against the stop either up or down. Again, in flight this won't work. Sorry for the long-winded explanation, but I'm hoping someone familiar with this autopilot can suggest something to look at.
midlifeflyer Posted October 5 Report Posted October 5 19 minutes ago, Fly Boomer said: Now, after about 5 seconds, the trim wheel starts creeping slowly nose up. Takes at least a minute to get all the way nose up. I'm not sure what it's headed toward, but in flight this would not work. Just to clarify, you are saying when you engage MET, (1) it takes 3-5 seconds to do anything and (2) once it starts, it won't stop? The only time I've seen something similar, it's been with a KAP 140 and it was a servo issue. I've flown with the KAP 150 but have not come across this, so I'm not sure how similar they are. As an aside, I no longer do AP overpowering tests beyond holding the yoke in place for the brief time it takes to disconnect. I picked up the rationale from the more recent Garmins. In the case of real runaway trim it will fight you and make the out of trim condition worse, and I can't help but think that overpowering when not necessary can't be all that good for the system.
Rick Junkin Posted October 5 Report Posted October 5 I'm no autopilot expert, but I did operate a KAP 150 for a number of years. As I recall the pitch behavior on mine seemed a little wonky (technical term) if I played around with it on the ground as you've described but it worked fine in the air. For my preflight checks I pulled the yoke back about half way, approximately to the cruise position, and engaged to A/P to confirm it would initially hold it there. I'd then hit the trim switches on the yoke to disengage, re-select A/P and HDG and twizzle (another tech term) the HDG bug back and forth to confirm the yoke moved appropriately, and use the big red button to disengage. Other than running the trim both directions manually and with the yoke switches, that was the only ground check for pitch that I did. With the airplane sitting on the gear in it's classic Mooney nose-high attitude the A/P is going to command pitch changes it thinks are needed to maintain level "flight", and that's what I attributed the A/P pitch inputs on the ground to. Using the rocker switch on the KC-191 with only A/P selected is telling the A/P to change the pitch up or down, so since the airplane isn't moving in pitch I think (?) the computer will continue to command a pitch change in the direction you told it to go until it hits the stop. Is that what you're seeing? Bad on me, I didn't check the left/right trim switches independently, or exercise the panel rocker switch as part of my checks. I trusted the computer self-test caught everything I didn't physically manipulate. Hopefully one of our King A/P gurus will be by shortly to provide you with a more complete answer and assessment of what you've reported. The delays and trim wheel behavior you describe don't sound familiar.
Fly Boomer Posted October 5 Author Report Posted October 5 1 hour ago, midlifeflyer said: Just to clarify, you are saying when you engage MET, (1) it takes 3-5 seconds to do anything and (2) once it starts, it won't stop? I meant to say I checked that the autopilot would respond to changes in the the heading bug, and after that, I'm reading my checklist for the next step, and the trim wheel starts moving -- apparently uncommanded. Not fast, but I can't figure out where it thinks it's going.
Fly Boomer Posted October 5 Author Report Posted October 5 17 minutes ago, Rick Junkin said: Using the rocker switch on the KC-191 with only A/P selected is telling the A/P to change the pitch up or down, so since the airplane isn't moving in pitch I think (?) the computer will continue to command a pitch change in the direction you told it to go until it hits the stop. Is that what you're seeing? That sounds right. Every time I run my checklist, my notes get better, so I'll have to verify.
Fly Boomer Posted October 5 Author Report Posted October 5 1 hour ago, midlifeflyer said: Just to clarify, you are saying when you engage MET, (1) it takes 3-5 seconds to do anything and (2) once it starts, it won't stop? When I use the rocker on the autopilot head to change pitch, it seems slow to react -- both to start, and to stop once started. I feel like I'm chasing it up and down.
Fly Boomer Posted Tuesday at 06:52 PM Author Report Posted Tuesday at 06:52 PM @Jake@BevanAviation does this PFT failure sound like anything you have seen?
Yetti Posted Tuesday at 07:10 PM Report Posted Tuesday at 07:10 PM I would think Rick has the answer. The plane on the ground is not level. Usually the leveling point is above the comm door in the rear. See your S&M manual for leveling instructions.
Fly Boomer Posted Wednesday at 11:26 AM Author Report Posted Wednesday at 11:26 AM 16 hours ago, Yetti said: I would think Rick has the answer. The plane on the ground is not level. Usually the leveling point is above the comm door in the rear. See your S&M manual for leveling instructions. I would be surprised if leveling before each preflight is a requirement. Also, I guess I would have expected King to have said something about leveling in their documentation. I need to get back to the airplane and nail down its behavior better.
Jake@BevanAviation Posted Wednesday at 12:40 PM Report Posted Wednesday at 12:40 PM (edited) @Fly Boomer Everything sounds normal if you are not supporting the yoke, the weight of the elevator and gravity is enough force to close the micro switches in the pitch servo to tell the computer to start auto trim. Normally there is a 3-5 second delay before auto trim will start. Auto trim will continue to run until you remove the load on the pitch servo. The only thing that sticks out to me is that you cannot overpower the trim servo. All servo slip clutches should be set around 22 inlb. Preflight test procedure is in the AFMS under section 4a. I have attached a copy of the AFMS for reference. AFMS KFC150 M20J-K.pdf Edited Wednesday at 12:41 PM by Jake@BevanAviation 1
Fly Boomer Posted Wednesday at 01:07 PM Author Report Posted Wednesday at 01:07 PM 19 minutes ago, Jake@BevanAviation said: Everything sounds normal if you are not supporting the yoke, the weight of the elevator and gravity is enough force to close the micro switches in the pitch servo to tell the computer to start auto trim. Thanks Jake! So if the yoke is full forward (resting position on the ground with an M20K), auto trim should start rolling in nose-up trim? I'll see if behavior changes if I hold the yoke back during PFT. Does the "slow to start" behavior with the pitch rocker on the KC-191 (as well as over-run when the rocker is released) sound normal?
Jake@BevanAviation Posted Wednesday at 03:05 PM Report Posted Wednesday at 03:05 PM @Fly Boomer when using the up/down rocker switch you are putting in a hard pitch up/down command. The servo drive should start out slow and get slightly faster the longer you hold the up/down rocker. You will not see full speed due to the tach feedback that is sent back to the flight computer to govern the speed of the servo. The servo will continue to drive when using the up/down rocker switch until you tell it to stop, easiest way to stop the drive is to use the CWS switch or disconnect the system. The way I check auto trim functions is pull the yoke out to elevator neutral and engage the system. I apply pressure to the yoke by pushing or pulling on the yoke and wait 3-5 seconds to see if auto trim start to drive. Once it starts driving I remove the pressure and check to see if the trim servo stopped driving and then repeat the process in the opposite direction. Ideally this test should be done with the engine running and the attitude gyro spooled up unless you have glass indicators.
Fly Boomer Posted Wednesday at 03:10 PM Author Report Posted Wednesday at 03:10 PM 2 minutes ago, Jake@BevanAviation said: The way I check auto trim functions is pull the yoke out to elevator neutral and engage the system. I apply pressure to the yoke by pushing or pulling on the yoke and wait 3-5 seconds to see if auto trim start to drive. Once it starts driving I remove the pressure and check to see if the trim servo stopped driving and then repeat the process in the opposite direction. Ideally this test should be done with the engine running and the attitude gyro spooled up unless you have glass indicators. This is good stuff. I will try this process as you described. BTW, when I am exercising the autopilot in the hangar, I activate my electric standby vacuum pump to spin the attitude gyro. Thanks again.
