I believe this is the switch you are looking for: NKK switch part No. MB2061SS1W01-CC
You can just use the cap to replace yours. The cap is a screw on as you probably found out the hard way. Not sure if one can get the button only, but the entire switch is $12 from TTI so it may be worth it even if you do not use the switch.
https://www.tti.com/content/ttiinc/en/apps/part-detail.html?partsNumber=MB2061SS1W01-CC&mfgShortname=NKK&utm=ga-shop1&utm_term=nkkmb2061ss1w01-cc&gad_source=1&gad_campaignid=1147404620&gbraid=0AAAAADvyBAbKzFqGooAmvtqZHrFicDT9_&gclid=EAIaIQobChMIx5n37ODKjwMVBSlECB0jrjtwEAQYASABEgKI0_D_BwE
MB2061SS1W01-CC NKK Switches Large Image
Many years ago I lost the red button too. I ended up buying a new switch just for the button. I did not get a cheap switch, but a more expensive one.
