Matthew P Posted July 21 Report Posted July 21 So, last weekend I replaces the wire running from the overhead to the outside airs scoop, whomever did it previously only had it to where the air scoop raised about 1/2 an inch and didn't allow for much airflow. Well, it opens up about 1.5 inches now and allows a bit better airflow but with the current interior vents it doesn't disperse the airflow very well...Just wanting to know what options might be out there to improve, not only the amount of air, but the displacement as well...I saw this picture in an older fourm but it didn't address the airflow, was just in with other pics that the OP did to his aircraft....any ideas? V/r Matt
00-Negative Posted July 21 Report Posted July 21 1 hour ago, Matthew P said: .I saw this picture in an older fourm but it didn't address the airflow, was just in with other pics that the OP did to his aircraft....any ideas? V/r That picture is my plane. I copied @Utah20Gflyer in the post listed below. I built a simple vacuum forming box and used 1/16 ABS to make mine. I bought the wemac vent from ebay. They are a game-changer. It directs airflow directly wherever you want and the aft vents can be directed at the pilot as well. Also, someone just uploaded a 3D print version on thingiverse a few days ago. Search Mooney. 1
Paul Thomas Posted July 22 Report Posted July 22 The quality of work from owners never ceases to amaze me! 42 minutes ago, 201Steve said: I will buy some if somebody has a 3d printer What does the overhead console look like on the 77J?
Nico1 Posted July 23 Report Posted July 23 On 7/21/2025 at 4:42 PM, 00-Negative said: Also, someone just uploaded a 3D print version on thingiverse a few days ago. Search Mooney. Found it: https://www.thingiverse.com/thing:7093747 Very helpful! Though the eyeball vent part is for a beech-style old vent. wonder if anyone might update the file for the standard round ones one can get on spurce?
201Steve Posted July 23 Report Posted July 23 On 7/21/2025 at 8:55 PM, Paul Thomas said: What does the overhead console look like on the 77J? Like an F. it’s the same concept as above, more or less.
Bartman Posted July 27 Report Posted July 27 If not already done, consider removing the air plenum and remove the “hog hair” fibers. This acts as a filter and if you were flying in rain with the vent open it would allow it to drop out and drain, but who flies with the overhead vent open in the rain? I found the filtration benefit did not meet my expectations and it acted more of an impediment to flow. When we redid mine a few years ago I also rigged the new wire to open a bit more than previous. It now opens about an inch and I now enjoy much improved air flow, but it does adds drag and decreases airspeed a few knots when open. I have no regrets about those minor changes.
FlyboyKC Posted July 29 Report Posted July 29 I just built these vent deflectors for my Mooney. I 3D printed them using PET-G filament, mainly because of the heat the plane is exposed to in the hot summer sitting in unventilated hanger. You can download the 3D files from this site (still a work in progress) https://www.mypilotflyer.com/3Dproject.html NOTE: if others have 3D parts they would like to share I will add them to my website for download. My goal is to share projects throughout the community.
Hank Posted July 29 Report Posted July 29 On 7/27/2025 at 10:23 AM, Bartman said: When we redid mine a few years ago I also rigged the new wire to open a bit more than previous. It now opens about an inch and I now enjoy much improved air flow, but it does adds drag and decreases airspeed a few knots when open. This is how mine opens. I ain't changed nothin!
Matthew P Posted July 30 Author Report Posted July 30 On 7/23/2025 at 1:07 PM, Nico1 said: Found it: https://www.thingiverse.com/thing:7093747 Very helpful! Though the eyeball vent part is for a beech-style old vent. wonder if anyone might update the file for the standard round ones one can get on spurce? Just printed them off and found the vents on ebay....will send picture when installed. 5
Old Chub Posted Monday at 02:19 AM Report Posted Monday at 02:19 AM (edited) Hi everyone, Based on the strong interest I’ve seen for a solution like this, I’ve gone ahead and started designing a replacement overhead eyeball air vent for our Mooneys. After some prototyping and refinement, I'm happy to share that the design is moving forward and is close to ready for production. I will make the promise of getting any order shipped by August 29th 2025. To get a better sense of demand and help fund the initial run, I’ve opened preorders on my website. If this is something you've been looking for or needing, you can check it out here: https://www.smcustomproducts.com/shop/p/mooney-m20-overhead-eyeball-air-vent Your feedback and support are really appreciated—whether you're ready to preorder or just want to share your thoughts. I'm always open to suggestions as I fine-tune the final version. If you aren't interested in a Preorder and would just wait until I have the production unit ready you can fill out my contact page here and I'll email once it is ready: https://www.smcustomproducts.com/contact Thanks for looking and fly safe! — Sam Mose, Old Chub Edited Monday at 02:22 AM by Old Chub 2
EricJ Posted Monday at 02:41 PM Report Posted Monday at 02:41 PM I would suggest leaving the end either just a hole or completely unfinished so that any vent could be used, like the following: https://www.amazon.com/EATAKWARD-Universal-Shuttered-Dashboard-Replacement/dp/B0DPYHGMWM
DCarlton Posted Monday at 05:02 PM Report Posted Monday at 05:02 PM 14 hours ago, Old Chub said: Hi everyone, Based on the strong interest I’ve seen for a solution like this, I’ve gone ahead and started designing a replacement overhead eyeball air vent for our Mooneys. After some prototyping and refinement, I'm happy to share that the design is moving forward and is close to ready for production. I will make the promise of getting any order shipped by August 29th 2025. To get a better sense of demand and help fund the initial run, I’ve opened preorders on my website. If this is something you've been looking for or needing, you can check it out here: https://www.smcustomproducts.com/shop/p/mooney-m20-overhead-eyeball-air-vent Your feedback and support are really appreciated—whether you're ready to preorder or just want to share your thoughts. I'm always open to suggestions as I fine-tune the final version. If you aren't interested in a Preorder and would just wait until I have the production unit ready you can fill out my contact page here and I'll email once it is ready: https://www.smcustomproducts.com/contact Thanks for looking and fly safe! — Sam Mose, Old Chub Since you asked, why does it need to extend so far down from the headliner? I'm frequently hitting my head on things in the cockpit. Unless there's a functional reason, think I'd like to see it as flush with the headliner as possible while still improving the angle and flow towards the occupants. 2
201Steve Posted Tuesday at 12:32 AM Report Posted Tuesday at 12:32 AM 7 hours ago, DCarlton said: Since you asked, why does it need to extend so far down from the headliner? I'm frequently hitting my head on things in the cockpit. Unless there's a functional reason, think I'd like to see it as flush with the headliner as possible while still improving the angle and flow towards the occupants. Also concerned about this. All the others I’ve seen have been goofy looking when installed bc they are so long.
Flyler Posted Tuesday at 02:21 AM Report Posted Tuesday at 02:21 AM On 7/29/2025 at 12:35 PM, FlyboyKC said: I just built these vent deflectors for my Mooney. I 3D printed them using PET-G filament, mainly because of the heat the plane is exposed to in the hot summer sitting in unventilated hanger. You can download the 3D files from this site (still a work in progress) https://www.mypilotflyer.com/3Dproject.html NOTE: if others have 3D parts they would like to share I will add them to my website for download. My goal is to share projects throughout the community. https://www.thingiverse.com/thing:6830500 Here's an "improved" rear seat recline lever I made.
Old Chub Posted Wednesday at 01:22 AM Report Posted Wednesday at 01:22 AM On 8/4/2025 at 12:02 PM, DCarlton said: Since you asked, why does it need to extend so far down from the headliner? I'm frequently hitting my head on things in the cockpit. Unless there's a functional reason, think I'd like to see it as flush with the headliner as possible while still improving the angle and flow towards the occupants. Thanks for the suggestion - I'll incorporate a more flush design and see how it fits with the headliner, I have a trip planned this week and didn't want to take apart the headliner panel just yet.
Old Chub Posted Wednesday at 01:22 AM Report Posted Wednesday at 01:22 AM On 8/4/2025 at 9:41 AM, EricJ said: I would suggest leaving the end either just a hole or completely unfinished so that any vent could be used, like the following: https://www.amazon.com/EATAKWARD-Universal-Shuttered-Dashboard-Replacement/dp/B0DPYHGMWM I plan on using eyeball vents from Spruce for consistency.
EricJ Posted Wednesday at 04:29 AM Report Posted Wednesday at 04:29 AM 3 hours ago, Old Chub said: I plan on using eyeball vents from Spruce for consistency. It just means they're not useful to anybody who wants to use a different vent.
TaildraggerPilot Posted 18 hours ago Report Posted 18 hours ago On 8/4/2025 at 1:02 PM, DCarlton said: Since you asked, why does it need to extend so far down from the headliner? I'm frequently hitting my head on things in the cockpit. Unless there's a functional reason, think I'd like to see it as flush with the headliner as possible while still improving the angle and flow towards the occupants. It might have something to do with the structure of the plenum in the roof, as well as the ability to mount the vent adapters.
