My KX-155 is getting a bit long in the tooth ('crunchy' knobs, a couple of missing segments, occasional 'buzzing') so I'm looking at repair/replacement.  The repair cost and lead-time is getting to where buying a used one (around $2500 from Bennett Avionics) is looking good.  For not much more I can 'upgrade' to a KX-165.  But I have no idea if I can just slide into the KX-155 rack without any issues (like needing a different indicator).
Anyone done this, know for sure?
You can. The KX-165 has an internal VOR decoder. If you want to use it, you have to add a couple of wires. If not, just plug in the 165.
Thanks!
The VOR decoder is the feature I like....just need to figure out which wires:D
My understanding was that the KX-165 was only made in a 28v version. So unless you have a step up transformer (or plan to install one), I think the answer is no for a vintage Mooney.
This link shows both versions 14v and 28v.  Not sure if tge 14v are available, but tgey seem to have existed at some point.
https://www.seaerospace.com/sales/product/BendixKing/KX-165?srsltid=AfmBOooIJjJzNpuai_Ihsgz2WLXdFiRDQsAOqOxpGk1GsmvH5pN64exp
I had my 155 refurbished a few years ago; new display; new lenses; new knobs (the internal plastic parts that create the detents for the frequencies).  It's a great #2 radio now.  And there's NO software.  :>
I too have a referb kx155, solid radio/nav…
-Don
On 7/3/2025 at 5:41 PM, MikeOH said:
Thanks!
I think you are referring to the 'radial indicator' feature.
The KX 155 needs an indicator like a KI209 that has the internal decoder.  The KX165 has this decoder in the radio, and needs an indicator like a KI206.
Last time I looked, I think you can slide a KX165 into a 155 position and it will work.  But not the other way around.
Aerodon
Aerodon
Yes, ‘radial indicator’
One of my concerns was if the 165 would drive the KI209 that I have, or if I would need to change it to a KI206.
I pretty sure the KX-165 will drive both indicators. You will need to add some wiring to make the 209 work. I have a bunch of King pins (actually Molex) that I doubt I’ll ever use, if you need some.
I'm looking at the KX155/165 IM.  If it is wire for a KX155 with glideslope, I am not seeing any extra wiring.  The composite output and G/S wires should already go to the KI209.
If you install a KI206, then yes, the composite output loops back to the other connecter, and a new set of wires to the KI206.
I'm thinking it will work without modification
Don
Don
Yep, I had them backwards.
Actually, the 155 and 155a are a digital radios.  The have firmware which is a pretty much software.
I think a different indicator (OBS) is required for the 165.
UGH!  That has been my concern.  It does appear there are opinions, both ways!  Not sure how to be certain.
I may well just buy a used KX-155 if I can't be sure a KX-165 is truly 'plug-n-play'; not worth buying another indicator and rewiring, however minor. I was just hoping to 'upgrade' if I had to buy another radio.
KX-200 is supposed to be a direct "slide-in" replacement for KX 155 or 165 units. I guess that is an "upgrade" option without having to dig into the panel and wiring. My 165 (secondary) is probably on its way out so I may be in the same boat as you. At about 5 AMUs it is not cheap, but worth considering. I am thinking about going thsi route when my radio bites the dust. I definitely do not want to dig into the rats nest behind the panel at this time. I know that we can get cheaper new radio, but the labor cost woud likely exceed the savings.
26 minutes ago, Fly Boomer said:
I often turn to the Bennett web site -- they are typically quite detailed and thorough.
Doesn't look promising based on what I found on their site:
