MikeOH Posted July 4, 2025 Report Posted July 4, 2025 My KX-155 is getting a bit long in the tooth ('crunchy' knobs, a couple of missing segments, occasional 'buzzing') so I'm looking at repair/replacement. The repair cost and lead-time is getting to where buying a used one (around $2500 from Bennett Avionics) is looking good. For not much more I can 'upgrade' to a KX-165. But I have no idea if I can just slide into the KX-155 rack without any issues (like needing a different indicator). Anyone done this, know for sure?
N201MKTurbo Posted July 4, 2025 Report Posted July 4, 2025 You can. The KX-165 has an internal VOR decoder. If you want to use it, you have to add a couple of wires. If not, just plug in the 165. 1
MikeOH Posted July 4, 2025 Author Report Posted July 4, 2025 15 minutes ago, N201MKTurbo said: You can. The KX-165 has an internal VOR decoder. If you want to use it, you have to add a couple of wires. If not, just plug in the 165. Thanks! The VOR decoder is the feature I like....just need to figure out which wires
AndreiC Posted July 4, 2025 Report Posted July 4, 2025 My understanding was that the KX-165 was only made in a 28v version. So unless you have a step up transformer (or plan to install one), I think the answer is no for a vintage Mooney.
Ragsf15e Posted July 4, 2025 Report Posted July 4, 2025 2 minutes ago, AndreiC said: My understanding was that the KX-165 was only made in a 28v version. So unless you have a step up transformer (or plan to install one), I think the answer is no for a vintage Mooney. This link shows both versions 14v and 28v. Not sure if tge 14v are available, but tgey seem to have existed at some point. https://www.seaerospace.com/sales/product/BendixKing/KX-165?srsltid=AfmBOooIJjJzNpuai_Ihsgz2WLXdFiRDQsAOqOxpGk1GsmvH5pN64exp
AndreiC Posted July 4, 2025 Report Posted July 4, 2025 Oops, I think I confused the KX165 with the KX155A.
DCarlton Posted July 4, 2025 Report Posted July 4, 2025 17 hours ago, MikeOH said: My KX-155 is getting a bit long in the tooth ('crunchy' knobs, a couple of missing segments, occasional 'buzzing') so I'm looking at repair/replacement. The repair cost and lead-time is getting to where buying a used one (around $2500 from Bennett Avionics) is looking good. For not much more I can 'upgrade' to a KX-165. But I have no idea if I can just slide into the KX-155 rack without any issues (like needing a different indicator). Anyone done this, know for sure? I had my 155 refurbished a few years ago; new display; new lenses; new knobs (the internal plastic parts that create the detents for the frequencies). It's a great #2 radio now. And there's NO software. :> 3
hammdo Posted July 4, 2025 Report Posted July 4, 2025 I too have a referb kx155, solid radio/nav… -Don
Aerodon Posted July 5, 2025 Report Posted July 5, 2025 On 7/3/2025 at 5:41 PM, MikeOH said: Thanks! The VOR decoder is the feature I like....just need to figure out which wires I think you are referring to the 'radial indicator' feature. The KX 155 needs an indicator like a KI209 that has the internal decoder. The KX165 has this decoder in the radio, and needs an indicator like a KI206. Last time I looked, I think you can slide a KX165 into a 155 position and it will work. But not the other way around. Aerodon
MikeOH Posted July 5, 2025 Author Report Posted July 5, 2025 3 hours ago, Aerodon said: I think you are referring to the 'radial indicator' feature. The KX 155 needs an indicator like a KI209 that has the internal decoder. The KX165 has this decoder in the radio, and needs an indicator like a KI206. Last time I looked, I think you can slide a KX165 into a 155 position and it will work. But not the other way around. Aerodon Yes, ‘radial indicator’ One of my concerns was if the 165 would drive the KI209 that I have, or if I would need to change it to a KI206.
N201MKTurbo Posted July 5, 2025 Report Posted July 5, 2025 4 hours ago, MikeOH said: Yes, ‘radial indicator’ One of my concerns was if the 165 would drive the KI209 that I have, or if I would need to change it to a KI206. I pretty sure the KX-165 will drive both indicators. You will need to add some wiring to make the 209 work. I have a bunch of King pins (actually Molex) that I doubt I’ll ever use, if you need some. 1
Aerodon Posted July 5, 2025 Report Posted July 5, 2025 6 minutes ago, N201MKTurbo said: I pretty sure the KX-165 will drive both indicators. You will need to add some wiring to make the 209 work. I have a bunch of King pins (actually Molex) that I doubt I’ll ever use, if you need some. I'm looking at the KX155/165 IM. If it is wire for a KX155 with glideslope, I am not seeing any extra wiring. The composite output and G/S wires should already go to the KI209. If you install a KI206, then yes, the composite output loops back to the other connecter, and a new set of wires to the KI206. I'm thinking it will work without modification Don 1
N201MKTurbo Posted July 5, 2025 Report Posted July 5, 2025 12 minutes ago, Aerodon said: I'm looking at the KX155/165 IM. If it is wire for a KX155 with glideslope, I am not seeing any extra wiring. The composite output and G/S wires should already go to the KI209. If you install a KI206, then yes, the composite output loops back to the other connecter, and a new set of wires to the KI206. I'm thinking it will work without modification Don Yep, I had them backwards.
skykrawler Posted July 7, 2025 Report Posted July 7, 2025 On 7/4/2025 at 1:38 PM, DCarlton said: I had my 155 refurbished a few years ago; new display; new lenses; new knobs (the internal plastic parts that create the detents for the frequencies). It's a great #2 radio now. And there's NO software. :> Actually, the 155 and 155a are a digital radios. The have firmware which is a pretty much software. I think a different indicator (OBS) is required for the 165.
MikeOH Posted July 7, 2025 Author Report Posted July 7, 2025 2 hours ago, skykrawler said: I think a different indicator (OBS) is required for the 165. UGH! That has been my concern. It does appear there are opinions, both ways! Not sure how to be certain. I may well just buy a used KX-155 if I can't be sure a KX-165 is truly 'plug-n-play'; not worth buying another indicator and rewiring, however minor. I was just hoping to 'upgrade' if I had to buy another radio.
IvanP Posted July 8, 2025 Report Posted July 8, 2025 1 hour ago, MikeOH said: UGH! That has been my concern. It does appear there are opinions, both ways! Not sure how to be certain. I may well just buy a used KX-155 if I can't be sure a KX-165 is truly 'plug-n-play'; not worth buying another indicator and rewiring, however minor. I was just hoping to 'upgrade' if I had to buy another radio. KX-200 is supposed to be a direct "slide-in" replacement for KX 155 or 165 units. I guess that is an "upgrade" option without having to dig into the panel and wiring. My 165 (secondary) is probably on its way out so I may be in the same boat as you. At about 5 AMUs it is not cheap, but worth considering. I am thinking about going thsi route when my radio bites the dust. I definitely do not want to dig into the rats nest behind the panel at this time. I know that we can get cheaper new radio, but the labor cost woud likely exceed the savings. 1
Fly Boomer Posted July 8, 2025 Report Posted July 8, 2025 2 hours ago, MikeOH said: Not sure how to be certain. I often turn to the Bennett web site -- they are typically quite detailed and thorough. 1
MikeOH Posted July 8, 2025 Author Report Posted July 8, 2025 26 minutes ago, Fly Boomer said: I often turn to the Bennett web site -- they are typically quite detailed and thorough. Doesn't look promising based on what I found on their site: 1
