testwest Posted October 23, 2009 Report Posted October 23, 2009 Hi everyoneWe have modified our 1977 M20J with a Lopresti cowl, Hartzell blended airfoil prop and Powerflow exhaust, so we have the stock M20J cowl, McCauley prop and stock exhaust system (drilled for 4-cylinder EGT) for sale. Best offer for one or all, they are currently located in Mojave, California. Edit: OK guys, first $1900 for a Mooney 201 cowl located in Mojave CA takes it, you come and pick it up. norman.e.howell (at) boeing dot com I spelled it out to defeat the spam-bots!Norman and Gretchen Howell1977 Mooney M20J N201JX Quote
FlyingAggie Posted October 23, 2009 Report Posted October 23, 2009 Have you seen any performance improvement from the new cowl and prop? Alan Quote
testwest Posted October 23, 2009 Author Report Posted October 23, 2009 Yes, three knots from the prop alone, the Lopresti/Powerflow combo should fly around second weekend in November. Quote
testwest Posted October 25, 2009 Author Report Posted October 25, 2009 Bump, see the edit above. Quote
testwest Posted January 18, 2010 Author Report Posted January 18, 2010 bump, see the second edit above! Quote
testwest Posted January 18, 2010 Author Report Posted January 18, 2010 Edit two: See testwest's gallery for pictures of the cowl, prop and spinner with captions. $1900 for the cowl, $1900 for the prop, $800 for a nearly new spinner! Quote
drpep Posted January 18, 2010 Report Posted January 18, 2010 Hi Folks C-FVWP 20E here and I have always wondered if a 201 cowling could be retrofitted to my 20E. Currently I have a lower cowl cover which I consider to be half way to a good idea. If the cowling above can be retrofitted I certainly would be nterested. ANy thoughts would be wecome Philip Quote
testwest Posted January 19, 2010 Author Report Posted January 19, 2010 Hi Philip Take a look at Top Gun Aviation's conversion of a 1969 F model with the 201 cowling, the web site is here: http://www.topgunaviation.net/topgunaviation/id9.html Also go up a level and look at the other pages on the site detailing the ongoing mods to their F, it is really nice. Here is their contact info: Mark Rouch mark at topgunaviation dot net and Tom Richardi menace at topgunaviation dot net Looked at your plane in the gallery, very classy. We also have the intake air box and a few other bits you would need that were removed for our Lopresti cowl. Thanks! Quote
testwest Posted January 21, 2010 Author Report Posted January 21, 2010 Prop SOLD! Cowl. spinner, intake airbox, ram air valve, exhaust and nose gear doors still available. Quote
Parker_Woodruff Posted January 22, 2010 Report Posted January 22, 2010 How much for just the cowl flaps? One of mine has a very small hole chaffed in the fiberglass from the exhaust pipe at some point in its 7100 hour life......maybe it's repairable though... Quote
testwest Posted January 22, 2010 Author Report Posted January 22, 2010 Sorry, Parker, I am not interested in removing and selling the cowl flaps separately. Selling you just the cowl flaps would make the remaining cowl virtually unsellable. The entire package that was removed for the Lopresti cowl mod is worth far more as a whole to someone who wants to upgrade a 200hp E or F to a 201-style front end. You may have better luck at a salvage yard, Dawson Aircraft in particular has a pretty nice searchable web site. If someone wants to make a decent offer for the cowl, spinner/backplate, intake airbox(less alternate air valve, that part is reused for the Lopresti upgrade), ram air valve and nose gear doors as a package just PM or email me! Thanks. Quote
Parker_Woodruff Posted January 22, 2010 Report Posted January 22, 2010 Quote: JimR Parker, Your cowl flaps are made out of fiberglass? That's interesting. Mine are aluminum. Jim Quote
fantom Posted January 22, 2010 Report Posted January 22, 2010 You can however use fiberglass to fix/patch a crack, chip or bite in aluminum. A friend did that to a bite in his inner gear door about 7 years ago, and it still looks great. Maybe a previous owner did the same to your cowl flap, Parker. Quote
