How are the ailerons?  There was a photo of one but couldn’t really determine the condition.  Can you take a few more pics,  looking down the trailing would be great.
Not great but not destroyed? Haven’t looked super close I can do that in morning maybe
Oil cooler seems to be in great shape. Incompatible with my E, but someone should snatch it!
Is the air intake duct damaged? Looks like that in the last picture.
I dunno. Mainly took pics to give general idea of what’s here, can look here in a bit
On 10/19/2024 at 7:27 PM, takair said:
There are two common locations to remove the tail, so no cutting required.  The entire tail comes off with only a few bolts .  You will see some covers just below the front edge of the tail.  That would also give you nice mounting points and may save the tail in case you find a buyer later for another airplane.
Ya sorry bout lingo.
I guess I assumed a wall hanger guy wanted more than where the section was mated?
On 10/19/2024 at 10:39 PM, MB65E said:
Hi!
I’ll take both main trailing links from above the pivots. Basically I’m after the MLG axels but it’s all one assembly.
nose gear doors bent?
nose truss assembly?
reason for cutting it up?
-Matt
Ok I’ll look at gettin it off there
1 hour ago, saltydecimator said:
Where are those? I think it has manual trim but I’m real foggy on how this thing works
If they are there they are in the tail section I believe, I think you can spot them from within the battery access area - connected to the elevator control rod. There are usually two - one with a blue vacuum line and the other with a yellow. The pitch servos are the lighter color(not black) as far as I have seen. Picture added from other user with pitch servo in plastic bag. Mounted near the rudder servo.
Ok I will look
On 11/7/2024 at 5:44 AM, saltydecimator said:
Ok I will look
I don’t see any servos. I think this one is all mechanical? Unless I’m not looking right. But I traced linkage from tail into belly and up under cockpit?
My lil “ glamour “model  shore knows how to work it lolz
jeres the pics of cowling someone was asking about
