Mcstealth Posted March 17, 2024 Report Posted March 17, 2024 Question please. Where does one send this kind of heater for overhaul? It has low hours on the Hobbs meter, less than 200, but the owner says "something " is not working and it won't turn on. It is out of Twin Turbo Comanche.
EricJ Posted March 17, 2024 Report Posted March 17, 2024 Janitrol heaters are extremely common and used on nearly all recip or unpressurized twins. You probably won't have to look far for an A&P that is familiar with them. They're very simple and it shouldn't be difficult to figure out what's wrong with it. 1
N201MKTurbo Posted March 17, 2024 Report Posted March 17, 2024 There are flow switches on the combustion blower and on the fuel supply, I would start there. Then make sure the spark ignition is working. 1
N201MKTurbo Posted March 17, 2024 Report Posted March 17, 2024 So, what doesn’t work? Does the main blower turn on? Does the heater not work? You need to have cabin airflow, combustion airflow and fuel pressure before the fuel solenoid will open. It never hurts to do a pressure test too. 1
Mcstealth Posted March 17, 2024 Author Report Posted March 17, 2024 1 hour ago, N201MKTurbo said: So, what doesn’t work? Does the main blower turn on? Does the heater not work? You need to have cabin airflow, combustion airflow and fuel pressure before the fuel solenoid will open. It never hurts to do a pressure test too. I will get down to brass tacks soon. The owner asked me who overhauls them and that is the extent of my knowledge right now. I figured I could ask here on the forum and get direction. I think I will tackle it. How hard could it be? Hehe. Did I just say that? Thanks. Get back with you soon.
Andy95W Posted March 17, 2024 Report Posted March 17, 2024 If it doesn’t “turn on”, it’s possible that the reset switch has to be pushed. That’s the little red button to the right of your picture with a couple of wires going to it. 1
Mcstealth Posted March 17, 2024 Author Report Posted March 17, 2024 1 hour ago, Andy95W said: If it doesn’t “turn on”, it’s possible that the reset switch has to be pushed. That’s the little red button to the right of your picture with a couple of wires going to it. Thank you.
N201MKTurbo Posted March 17, 2024 Report Posted March 17, 2024 I’ve heard the overhaul cost for these is very high. Around $5000. There are ADs that apply. If it doesn’t require an overhaul, I would try to fix it. 1
N201MKTurbo Posted March 17, 2024 Report Posted March 17, 2024 https://janitrol.aero It is a Hartzell company. 1
philiplane Posted March 18, 2024 Report Posted March 18, 2024 the best place to overhaul it is http://www.haroldhaskinsinc.com/ the second best place is on the label. AHE. But the main problem is often that they don't get used often enough. Which means the fuel lines from the shut off valve to the heater, and the wick inside the heater, are dry. So the heater may not be primed with fuel. It re-primes by turning it on FAN for a few minutes, and then to HEAT. Then it should be primed, and light off as it should.
Mcstealth Posted March 18, 2024 Author Report Posted March 18, 2024 58 minutes ago, philiplane said: the best place to overhaul it is http://www.haroldhaskinsinc.com/ the second best place is on the label. AHE. But the main problem is often that they don't get used often enough. Which means the fuel lines from the shut off valve to the heater, and the wick inside the heater, are dry. So the heater may not be primed with fuel. It re-primes by turning it on FAN for a few minutes, and then to HEAT. Then it should be primed, and light off as it should. Can they be tested on the ground?
Andy95W Posted March 18, 2024 Report Posted March 18, 2024 (edited) 1 hour ago, Mcstealth said: Can they be tested on the ground? Yes, but depending on the aircraft installation, it may need a source of fuel pressure before it will run. The POH should explain its use. Edited March 18, 2024 by Andy95W 2
Mcstealth Posted March 19, 2024 Author Report Posted March 19, 2024 23 hours ago, Andy95W said: Yes, but depending on the aircraft installation, it may need a source of fuel pressure before it will run. The POH should explain its use. Yes. The owner did say the heater needed fuel pressure. Thanks for the reminder. 1
EricJ Posted March 19, 2024 Report Posted March 19, 2024 1 hour ago, Mcstealth said: Yes. The owner did say the heater needed fuel pressure. Thanks for the reminder. Fuel pressure, spark, and airflow. Most of them have a lockout/safety switch that doesn't let it run unless there's sufficient air going through it, either from the fan or the ram inlet.
Andy95W Posted March 19, 2024 Report Posted March 19, 2024 @Mcstealth Janitrol-MaintenanceManual 2.pdf 1 1
Mcstealth Posted March 20, 2024 Author Report Posted March 20, 2024 On 3/19/2024 at 10:52 AM, Andy95W said: @Mcstealth Janitrol-MaintenanceManual 2.pdf 4.84 MB · 3 downloads Let's see if this has a trouble shooting guide.
cliffy Posted March 21, 2024 Report Posted March 21, 2024 I've done those on my own bench You can "overhaul" them but in most cases that is not necessary. IRAN is better There is a combustion can pressure check AD that needs to be complied with every year (I had a Twinkie non-turbo). Many shops can do the pressure check in the airplane. No need to take it out. There is also an AD on the fuel shutoff solenoid to check for leaks. Its a very simple system to repair IF the combustor can has no pressure leaks. Spark to light it off, fuel delivery (clogged nozzle) I've found this. Fuel pressure and air pressure to run Getting it out of the Twinkie is a project You might also try to remove each wire connection ONE AT A TIME and clean each with a wire tooth brush for good contact. It looks like it has been sitting for a long time. 1
Mcstealth Posted March 21, 2024 Author Report Posted March 21, 2024 2 hours ago, cliffy said: I've done those on my own bench You can "overhaul" them but in most cases that is not necessary. IRAN is better There is a combustion can pressure check AD that needs to be complied with every year (I had a Twinkie non-turbo). Many shops can do the pressure check in the airplane. No need to take it out. There is also an AD on the fuel shutoff solenoid to check for leaks. Its a very simple system to repair IF the combustor can has no pressure leaks. Spark to light it off, fuel delivery (clogged nozzle) I've found this. Fuel pressure and air pressure to run Getting it out of the Twinkie is a project You might also try to remove each wire connection ONE AT A TIME and clean each with a wire tooth brush for good contact. It looks like it has been sitting for a long time. Thank you for that. I will begin the process next week on Wednesday. Fingers crossed.
cliffy Posted March 24, 2024 Report Posted March 24, 2024 I did one on a Navajo many years ago also. They really are not THAT bad to do with the right factory repair book. Pressure check it and then trouble shoot to see why it doesn't light off- It can be done. 1
