Pinecone Posted September 30, 2022 Report Posted September 30, 2022 I am having an 830 installed. Where can/did you put the oil temp sensor? I have to keep the original one as the 830 is cannot be primary. Quote
pkellercfii Posted October 1, 2022 Report Posted October 1, 2022 My JPI oil temp probe, which feeds an EDM-800, is in the crankcase nose. —Paul Keller Quote
Jim F Posted October 5, 2022 Report Posted October 5, 2022 I installed my 830 oil temp probe on the front left oil galley right next to the prop governor. Quote
Pinecone Posted October 5, 2022 Author Report Posted October 5, 2022 The problem is, I have a hot prop. And that interferes with the location. Quote
WilliamR Posted October 19, 2022 Report Posted October 19, 2022 Probe tightly fits on my hot prop'ed 252. 1 Quote
Pinecone Posted October 19, 2022 Author Report Posted October 19, 2022 Thanks. I just returned the sensor. I will revisit this later and see if it will work. Quote
carusoam Posted October 20, 2022 Report Posted October 20, 2022 Often, The left side and right side of the engine have mirrored port holes… If the ship’s OilT sensor is on one side, the JPI can use the similar mirrored port… It may help to get a drawing of your engine’s oil system…. For planning purposes… Be sure the spot you pick… is proper for the temp you are looking to measure… as the oil heats up on the way to the end of the engine… PP thoughts only, -a- Quote
