Mooney-Shiner Posted November 2, 2022 Report Posted November 2, 2022 9 hours ago, EricJ said: I've not heard of using Mobil 1 for that, but it is not unusual, especially for certain engine types, to put some Marvel Mystery Oil (MMO) in the oil for the same purpose. Mike Busch has a procedure of ring flush of using mix of 1 gallon Varsol (mineral spirits), 1 gallon Xylene (dimethylbenzene), 2 quarts Aeroshell W100. Its a hydro locking procedure, but you are hydrolocking it by moving the prop by hand. DO NOT run your engine with ring flush mix. Quote
Tom 4536 Posted November 3, 2022 Report Posted November 3, 2022 On 11/1/2022 at 3:41 AM, tmo said: I've read, on the internet, so take that into account, about people adding a pint of automotive Mobil 1 0W20 for a few hours / last flight before an oil change. It supposedly helps clean things up. What do the smart people here think, apart from it being obviously an unapproved approach. But I guess so is Camguard in turbocharged engines. Is Camguard unapproved for use in turbocharged engines?? Quote
smwash02 Posted November 3, 2022 Report Posted November 3, 2022 21 minutes ago, Tom 4536 said: Is Camguard unapproved for use in turbocharged engines?? It's complicated. Quote
kortopates Posted November 3, 2022 Report Posted November 3, 2022 25 minutes ago, smwash02 said: It's complicated. Interestingly Continental used it, and actually required it, in an optional improved warranty program for 1 or 2 years with new engines in order to collect some good data. But nothing has ever been published or publicly released to date that I know of. 1 Quote
tmo Posted November 4, 2022 Report Posted November 4, 2022 Practical evidence from a sample of one TSIO-360 says it does not hurt. (I was trying to be funny in the previous post, sorry about that) 1 Quote
