Anyone know the diameter and length of the black vent hose? I’m looking to order one.
I’m also looking to order a direct replacement of the plastic kick plate if and knows where I can get one. I’ve seen replace plastic parts but none are direct replacements and need cutting etc..
Can’t help you on the black tube. Looks like there is enough room to get a caliper on the port it is attached to.
The side kick panels I found came from Plane Plastics but they required some trimming. I think all of these secondary suppliers of these parts are making copies of an original. You might be able to find someone who has ones from an upgrade that is in better condition than yours. You could also try to do the plastic repair and repaint path of your originals. These panels are pretty thin and crack easily — especially when big feet hit them.
If you are redoing the interior, you might want to look at the Spatial Designs alternative. Gets rid of the kick panels.
My C used 1 1/4” Orange SCAT tube to repair that line.
Looks like the same size, but not sure on the J.
We re-did a both lines and had 7’ for them both. Just measure what you have and buy it by the foot with a little extra. It’s flexible new, not hard like the aged black tubing.
+1 measure the tube, buy a better replacement…
There were a few black air hoses that rusted and fell apart in my old M20C…
Buying the replacement stuff was simply calling aircraft spruce…
Plane plastics for the plastic parts… newer, better, easy to fit… really low cost.
if dressing a forever-plane… follow Marauder’s advice….  :)
