N201MKTurbo Posted January 9, 2022 Report Posted January 9, 2022 On 1/6/2022 at 4:31 PM, RobertGary1 said: The original King equipment used radioactive gas! Not many are aware of that. As a result there really isn’t any county where it’s legal to make the old style displays. They ran at very high voltage so replacing it with something more modern is more than just swapping the display. I thought they were filled with neon. 1 Quote
carusoam Posted January 9, 2022 Report Posted January 9, 2022 Typical segmented gas discharge displays use neon… with some high voltage generated to make them work… https://www.eeeguide.com/segmented-gas-discharge-displays/ -a- Quote
tigers2007 Posted January 9, 2022 Report Posted January 9, 2022 Let us not forget the golden rule of the total cost of an avionics purchase and it’s installation: Cost of Avionic x 2 Quote
Alan Fox Posted January 9, 2022 Report Posted January 9, 2022 I sell late model , High serial #rd KX 155s , with 8130s and bench checked in 14 volt , for about 2300 dollars , 28 volt for about 1700 dollars , I generally only sell the later versions , I do not reccomend throwing a lot of money into the early ones , unless , they are the very late ones...... Usually -25 and later .. 2 Quote
Will.iam Posted January 11, 2022 Report Posted January 11, 2022 On 1/5/2022 at 11:58 AM, ukrsindicat@yahoo.com said: Keith Peshak fixed my MAC 1700 for $500. https://www.barnstormers.com/classified-1588254-King-KX-175B-NavCom-Repair.html?catid=16683 He gets your eqpt and tells you outright if its repairable. Called him. He doesn’t do kx-155 radioes said the capacitors leak and are very corrosive and to replace boards makes it not cost effective for them. 1 Quote
Mooney-Shiner Posted January 11, 2022 Report Posted January 11, 2022 Called him. He doesn’t do kx-155 radioes said the capacitors leak and are very corrosive and to replace boards makes it not cost effective for them. That’s unfortunate…I didn’t follow this thread closely, so not sure if anyone mentioned EBay. Even the “as is” items are covered by 30 days satisfaction policySent from my iPhone using Tapatalk Quote
carusoam Posted January 11, 2022 Report Posted January 11, 2022 There are various BK boxes that suffer from having leaking capacitors… Found when trying to get them fixed… Many after 30+ years in service… Some get fixed… -a- Quote
Will.iam Posted January 12, 2022 Report Posted January 12, 2022 On 1/10/2022 at 11:29 PM, carusoam said: There are various BK boxes that suffer from having leaking capacitors… Found when trying to get them fixed… Many after 30+ years in service… Some get fixed… -a- Actually after talking to bevanaviation.com they still do kx-155 and said ironically that units older than 1993 are better to repair as units produced after 1993 had capacitors with corrosive fluids compared to prior to 1993. Also they fix garmin boxes as well. Sent both off today, said they are at 5-7 day turnaround depending on if they have parts in stock. 1 Quote
corn_flake Posted January 13, 2022 Author Report Posted January 13, 2022 (edited) In case if any one with bad display. Perhaps this could be a god option? Found them on Google. OLED will probably last forever. Solder 13 wires and you are good to go. Just about any competence electronic technician can get it done under 30 minutes. Any pirep? https://www.kx155display.com/ Edited January 13, 2022 by corn_flake Quote
toto Posted January 13, 2022 Report Posted January 13, 2022 24 minutes ago, corn_flake said: In case if any one with bad display. Perhaps this could be a god option? Found them on Google. OLED will probably last forever. Solder 13 wires and you are good to go. Just about any competence electronic technician can get it done under 30 minutes. Any pirep? https://www.kx155display.com/ That is one strange website. Quote
Will.iam Posted January 13, 2022 Report Posted January 13, 2022 6 minutes ago, toto said: That is one strange website. Agreed. Can buy the whole company for 150 amu’s Quote
Will.iam Posted January 13, 2022 Report Posted January 13, 2022 Also no display option for 165 just 155. The 165 you have to get the whole radio. Weird. Quote
corn_flake Posted January 13, 2022 Author Report Posted January 13, 2022 (edited) Have you look at http://www.kx-155.com? That site is weird too. If you call the guy at KX-155, he sounded like he just woke up from a long nap. But, everyone says he does good work. After all, I think they do have to be kinda different if they are willing to work on 1980 technology. Edited January 13, 2022 by corn_flake Quote
hammdo Posted January 13, 2022 Report Posted January 13, 2022 Ed @kx-155 does great work... pm me if you have questions... -Don Quote
Jim Peace Posted January 13, 2022 Report Posted January 13, 2022 reminds me of the thread where the guy was going to replace one nav light with LED and not the other.... Quote
PT20J Posted January 16, 2022 Report Posted January 16, 2022 Mid Continent and Bevan also repair KX-155/165s. I don't see how you could make a viable business only repairing those. Quote
