tmo Posted December 4, 2021 Report Posted December 4, 2021 23 hours ago, Browncbr1 said: I got the JPI reinstalled with 3D print flush mount bracket and bezel. Share the STL, pretty please? Quote
Browncbr1 Posted December 6, 2021 Author Report Posted December 6, 2021 On 12/4/2021 at 4:47 PM, tmo said: Share the STL, pretty please? Here you go... I made one with generic mounting flanges, as your application will likely be different from mine, so you can cut and drill as needed. JPI 830 mount bezel.stl JPI 830 mount.stl 1 Quote
Browncbr1 Posted December 6, 2021 Author Report Posted December 6, 2021 I took some pieces of the left panel to match paint after cutting for the jpi. Orielly’s mixed a custom enamel to match and put it in an aerosol can. They are supposed to charge $32, but the guy insisted it was free after I bragged on him a little bit. I’m going to let the panel dry a few more days before applying placards. I upload a photo then. I purchased Avery 6521 for my laser jet to make placards. They came out very nice. $8 I’m also printing tow limits and don’t step on flap and other placards I’ve needed for a while. After I get the panel wrapped up, my next project is working on the baffles. I ordered all new reinforced baffle material, rivets, and some 4130 round bar to replace a missing threaded rod on the underside of #1&3. I 3D printed a tool to hold a wine bottle cork that I glue some scotchbrite pad to do circular brushing. Do you guys think this kind of finish would make my baffles look nice or is it too much? 2 Quote
NM Mooney Posted December 6, 2021 Report Posted December 6, 2021 2 hours ago, Browncbr1 said: I took some pieces of the left panel to match paint after cutting for the jpi. Orielly’s mixed a custom enamel to match and put it in an aerosol can. They are supposed to charge $32, but the guy insisted it was free after I bragged on him a little bit. I’m going to let the panel dry a few more days before applying placards. I upload a photo then. I purchased Avery 6521 for my laser jet to make placards. They came out very nice. $8 I’m also printing tow limits and don’t step on flap and other placards I’ve needed for a while. After I get the panel wrapped up, my next project is working on the baffles. I ordered all new reinforced baffle material, rivets, and some 4130 round bar to replace a missing threaded rod on the underside of #1&3. I 3D printed a tool to hold a wine bottle cork that I glue some scotchbrite pad to do circular brushing. Do you guys think this kind of finish would make my baffles look nice or is it too much? If 100% of the sheet metal had this finish, perhaps a bit much. But as an accent for certain pieces, I think it's sweet. But that's just me... Quote
Browncbr1 Posted December 7, 2021 Author Report Posted December 7, 2021 I got the placards on the panel today. Now it’s ready to install. I have a 3D print bezel that will go around the garwin gauges to make them look cleaner. 2 Quote
NM Mooney Posted December 8, 2021 Report Posted December 8, 2021 1 hour ago, Browncbr1 said: I got the placards on the panel today. Now it’s ready to install. I have a 3D print bezel that will go around the garwin gauges to make them look cleaner. Beautiful. Really coming along. Quote
Browncbr1 Posted December 10, 2021 Author Report Posted December 10, 2021 Today, I got the right panel put in and few other things. I was short a few screws and had to make unexpected adjustments behind the panel, but I’m glad to be done with it now. iPad now clips in nicely and can slide right if need to check the strikefinder. 2 Quote
Browncbr1 Posted January 5, 2022 Author Report Posted January 5, 2022 Lots of waiting on the engine…. Happy to report I finished the pilot yoke. Some of you guys may remember the copilot yoke I wrapped last year. I sandblast, clean, zinc, and prime before leather goes on. The mooney motif is Cnc laser etching. That’s a 3D printed iPhone holder that bolts in place of the clock. 7 Quote
Browncbr1 Posted January 5, 2022 Author Report Posted January 5, 2022 (edited) Earlier in this thread, I mentioned that I took my exhaust to a shop to get pressure checked and cleaned up. Well, he pressure checked it and then went on to other projects, so not much was accomplished…. So, I used my glass blasting cabinet and scotchbrite balls on my drill press to get them looking better. I’m pretty much done with all the side projects now, just waiting on the engine at this point. I posted before and after.. Im spending a little more time on the tail pipe, since that’s the bling that is seen from the exterior. I did this also to the heater shroud and muffler. I am told that they will rainbow blue after I run them. Edited January 5, 2022 by Browncbr1 3 Quote
N201MKTurbo Posted January 5, 2022 Report Posted January 5, 2022 33 minutes ago, Browncbr1 said: Earlier in this thread, I mentioned that I took my exhaust to a shop to get pressure checked and cleaned up. Well, he pressure checked it and then went on to other projects, so not much was accomplished…. So, I used my glass blasting cabinet and scotchbrite balls on my drill press to get them looking better. I’m pretty much done with all the side projects now, just waiting on the engine at this point. I posted before and after.. Im spending a little more time on the tail pipe, since that’s the bling that is seen from the exterior. I did this also to the heater shroud and muffler. I am told that they will rainbow blue after I run them. Another thread was talking how to make a plane go faster, well yours is going to go at least 10 KTS faster with that exhaust. People here at the airport are always giving me grief for cleaning, painting and polishing everything. You are making me look like a poser. It looks great! 1 1 Quote
Browncbr1 Posted January 6, 2022 Author Report Posted January 6, 2022 1 hour ago, N201MKTurbo said: Another thread was talking how to make a plane go faster, well yours is going to go at least 10 KTS faster with that exhaust. People here at the airport are always giving me grief for cleaning, painting and polishing everything. You are making me look like a poser. It looks great! Thanks man,,.. I just can’t go along with putting an ugly exhaust on a fresh engine. Hopefully it will actually result in a nice rainbow bluing. 1 Quote
Browncbr1 Posted February 8, 2022 Author Report Posted February 8, 2022 Week 13 that CSI has had my cases and still not done. Hopefully not much longer. Meanwhile, I got a call from the hose shop asking if I want to replicate the molded teflon hoses, or if I want to standard orange fire sleeve style. After a bit of conversation, it seems there is no real difference apart from asthetics and price. It seems that the inside core is the same braided metal hose. But, the molded teflon is about $240 more than orange fire sleeve. What do you guys think? The molded brown hose or the orange hose for less cost? They dip the ends of the fire sleeve in silicone before banding at the ends. Quote
Hank Posted February 8, 2022 Report Posted February 8, 2022 I replaced my oil lines a couple years ago, went with firesleeves on everything. I feel safer now . . . . Quote
Browncbr1 Posted February 8, 2022 Author Report Posted February 8, 2022 13 minutes ago, Hank said: I replaced my oil lines a couple years ago, went with firesleeves on everything. I feel safer now . . . . After more discussion with the engine shop, he said he's putting the orange fire sleeve hoses on everything because the insides are all the same teflon tubing with stainless steel braiding. The only difference is molded teflon fire sleeve or braided orange fire sleeve. So, I figured to go with what he said everyone else does and save a little coin. I'll put my old lines on the shelf. Thanks for the input Hank! 1 Quote
Igor_U Posted February 11, 2022 Report Posted February 11, 2022 On 2/8/2022 at 10:25 AM, Browncbr1 said: After more discussion with the engine shop, he said he's putting the orange fire sleeve hoses on everything because the insides are all the same teflon tubing with stainless steel braiding. The only difference is molded teflon fire sleeve or braided orange fire sleeve. So, I figured to go with what he said everyone else does and save a little coin. I'll put my old lines on the shelf. Thanks for the input Hank! I like the look of molded teflon hose but for my engine replacement, I went with standard fire sleeve hose with teflon tubing as per my IA recommendation. Mine were done by Herber in LA. Quote
Browncbr1 Posted February 11, 2022 Author Report Posted February 11, 2022 Well, today I got some good news and some bad news. Good news, the case is done. No cracks or anything. It is back in the shop’s hands now. Still waiting on crank and other steel parts. bad news, he said one of my cylinders was rejected due to a crack in the barrel. I was a little surprised because I understood the cylinder work had already been performed. I’ve never heard of a cracked barrel before. I wonder how a steel barrel cracks. I asked which cylinder, but haven’t heard back yet. Quote
A64Pilot Posted February 17, 2022 Report Posted February 17, 2022 (edited) Is it legal to have an aircraft exhaust Plasma / ceramic coated? Normally I wouldn’t bother, but your going to so much trouble to detail everything out that if it’s legal it may be worth it. It looks nice, and stays that way Edited February 17, 2022 by A64Pilot Quote
jamesm Posted February 19, 2022 Report Posted February 19, 2022 2 hours ago, GEE-BEE AEROPRODUCTS said: the other Guys hose shop have never installed Ain't that the truth. I had bought set of hoses from a supposedly well respected hose manufacture, I bought during my engine overhaul several years go thinking that it should fit. since they sell them as kit for my model and year Mooney and supposedly had gotten the sizes from Mooney . But when it came to installation one of the hoses wouldn't fit. So I called them for a refund I told them they reuse the fittings on someone else hoses but I got stuck with only half what I should have been refunded. I the past I would send my hoses to Sacramento Sky Ranch John and the crew always did me right. Not sure if they are still around. I know His books are still in print. Very well written in my opinion. Quote
jetdriven Posted February 19, 2022 Report Posted February 19, 2022 The 124J hoses also have a tighter bend radius, and also, a firesleeve hose, how do you inspect that? The hoses are underneath of the firesleeve whereas the 124J Integral sleeve hose, the jacket is part of the hose. Also, spaceX uses 124j on spacecraft…. I figure it’s a good enough for spacecraft a good enough for my plane Quote
Browncbr1 Posted February 27, 2022 Author Report Posted February 27, 2022 Looks like the crank was finished this past week, as I just received these photos from the shop. Coming together now. it’s strange to see my engine so clean and shiny. it wouldn’t be a proper aviation shop without a dog running around. 1 Quote
jetdriven Posted February 27, 2022 Report Posted February 27, 2022 On 11/5/2021 at 11:49 AM, Browncbr1 said: I'm about to order some parts and came to the option to decide between Lord or Barry engine mounts. Which is better? $790 vs $535, but i just want the best long lasting one.. A clients twin Comanche had this annoying shudder and resonant vibration. Related to rpm. 100 hours on engines and props. New Barry mounts. Balanced props. New lord mounts solved it. Quote
Browncbr1 Posted February 27, 2022 Author Report Posted February 27, 2022 17 hours ago, jetdriven said: A clients twin Comanche had this annoying shudder and resonant vibration. Related to rpm. 100 hours on engines and props. New Barry mounts. Balanced props. New lord mounts solved it. I’ve heard it go both ways. I’ve also heard of gel packs in the Lords rupturing after 6 months. We’ll see how it all works out soon, as the engine is starting to come together. Hurray! 1 Quote
jetdriven Posted March 2, 2022 Report Posted March 2, 2022 On 2/27/2022 at 2:55 PM, Browncbr1 said: I’ve heard it go both ways. I’ve also heard of gel packs in the Lords rupturing after 6 months. We’ll see how it all works out soon, as the engine is starting to come together. Hurray! The M20J Lord mounts have gel packs, but the twin Comanche ones do not. But it still fixed the shudder. It was the worst I ever saw, as the engines come into phase the plane would shake at some kind of amplified magnitude you think the tail is going to come off it was almost dangerous. Quote
Browncbr1 Posted March 2, 2022 Author Report Posted March 2, 2022 10 hours ago, jetdriven said: The M20J Lord mounts have gel packs, but the twin Comanche ones do not. But it still fixed the shudder. It was the worst I ever saw, as the engines come into phase the plane would shake at some kind of amplified magnitude you think the tail is going to come off it was almost dangerous. that sounds horrible. did it do it just with both engines running coming into phase? was there any shaking when the engines were run independently? maybe it was some weird harmonic? I've heard that the gel packs mainly just help with the torque wobble during shut down.... Quote
