  On 4/22/2021 at 6:07 PM, EricJ said:
While my experiences with aircraft spruce have generally been good to acceptable, I ordered the "Mooney" jacks from them, which did not fit under my wings and so were unusable.
These:
https://www.aircraftspruce.com/catalog/topages/jackj106.php
I left a review on the page, dated Dec. 28th.   It was a pretty miserable experience, mostly due to the poor handling of the issue.   I wound up buying jacks elsewhere.
Expand
i have those Jacks ..they work fine on my Bravo using the lasar jack cone
if my plane had been in the shop getting engine work (lifters ,seals)and I had a trip sheduled soon after ward., i would have .as others suggusted been more proactive in sourcing parts....especially continental or other PMI engine parts .In ,this case ,I have to blame the shop for not actively sourcing these parts.avial,direct continental etc...and by phone ,...sorry for your canceled trip...
  On 4/22/2021 at 5:28 PM, Amelia said:
Thank you, dear one. I need four more lifters, seals, rods, and assorted other bits for my io550. And another 8 hours to install the dang things. Would have been easy if Aircraft Spruce had extracted its corporate head from wherever it was stuffed two weeks ago and accomplished what we paid for, including expedited shipping. But that was evidently too much to ask of a gum- chewing dimwit. Yeah...I am still just *a little*  upset. But warms my heart to think there are still good folk like you eager to lend a hand. I fear we are SOL this time. Now must go unpack our bags and x the flight plan. Thanks most sincerely!,
Expand
Generally I have had good experiences with Spruce.  However, for engine parts I suggest.  I have had good service form both of them
Seth at Performance Aircraft Parts, Inc. in Arkansas
870-423-3322
or
Aircraft Specialties Services
918-836-6872
  On 4/26/2021 at 8:27 PM, EricJ said:
I have the lasar jack tie-downs as well.    It wasn't even close to fitting.
Expand
As the gear doughnuts, biscuits, disc or what ever you like to call them cause the plane to sit lower as they age, I fabricated my own jacks but the minimum height was based off a set of jacks from Spruce. My disc were in pretty bad shape and neither set of jacks would fit under the wings, had to roll the plane up on 2”x”12” planks, once the new disc were installed it wasn’t an issue
  • 2 months later...
You just get your next door neighbor to put their spine along the lower wing spar and push up with their legs. It will raise the wing up enough to get the jack in and save them a gym membership!
Also airing the tires up usually gets it.
Edited by N201MKTurbo
A few weeks ago while ferrying a Cirrus from Wyoming to Ontario we broke down with alternator issues in Wisconsin.  I called Spruce in California, they had the parts I needed on hand and got them boxed and shipped out, but with no guarantee that Fed Ex would deliver the parts.  Both companies came thru, parts arrived and installed before noon, home by quitting time.
