whiskytango Posted December 17, 2020 Report Posted December 17, 2020 After a prolonged period of hand flying (thanks Century) I am aware that my K model does not fly straight, and there is a noticeable effort required to stay level in the roll axis. I want to correct this problem before getting a GFC-500 installed. I know I could fly to Texas and have DMax solve the problem, but I was wondering if there is a Mooney A&P in the Southeast who is good at this type of work. 1
N201MKTurbo Posted December 17, 2020 Report Posted December 17, 2020 It isn't rocket science to fix a heavy wing. You can either adjust the flap stops, or trim (bend) the aileron trailing edges. It is always good to level the ailerons first. BTW, this cannot be done with travel boards, it requires test flights. 3
flynboy Posted December 17, 2020 Report Posted December 17, 2020 During my annual this year, AGL Aviation noticed my rudder rigging was off and adjusted it. They're over in Morganton, NC a little ways from you, but I highly recommend. 2
RobertGary1 Posted December 17, 2020 Report Posted December 17, 2020 I second the caution of putting travel boards on it unless it’s really bad. The boards are great as a starting point when you install a control surface but you have to fly it to know how to trim it. You’re probably already closer to true than the travel boards will get you. 1
whiskytango Posted December 17, 2020 Author Report Posted December 17, 2020 5 hours ago, flynboy said: During my annual this year, AGL Aviation noticed my rudder rigging was off and adjusted it. They're over in Morganton, NC a little ways from you, but I highly recommend. Thanks, I will give them a call 1
Parker_Woodruff Posted December 17, 2020 Report Posted December 17, 2020 AGL is a great option just like Maxwell or SWTA. 1
Guest Posted December 18, 2020 Report Posted December 18, 2020 I’ll be the odd man out here. I wouldn’t take it to anyone who doesn’t have rigging boards and certainly wouldn’t let them touch it. It’s not rocket science but proper tools are required. Clarence
Parker_Woodruff Posted December 18, 2020 Report Posted December 18, 2020 Anyone can make a Mooney fly straight, but those without rigging boards will also make the plane 3 knots slower. 1
whiskytango Posted December 18, 2020 Author Report Posted December 18, 2020 24 minutes ago, Parker_Woodruff said: Anyone can make a Mooney fly straight, but those without rigging boards will also make the plane 3 knots slower. That says it all. Thanks @Parker_Woodruff 1
