75_M20F Posted December 1, 2020 Report Posted December 1, 2020 Electric fuel boost pump is off. Idle power on the ramp. My fuel pressure gauge is jumping around about 2 PSI. (See video). Engine runs fine and makes power. Any ideas what is causing this? Thanks! Fuel_pressure.mp4 Quote
RLCarter Posted December 1, 2020 Report Posted December 1, 2020 What happens when you turn on the electric pump?... if it still moves around I would think it’s in the gauge Quote
carusoam Posted December 1, 2020 Report Posted December 1, 2020 Set the fuel gauge hose up again... a certain amount of air belongs in their... the air acts as a buffer... I believe the procedure is in the MM... @Bob_Belville was our go to guy to describe this affect... PP thoughts only, Best regards, -a- Quote
75_M20F Posted December 3, 2020 Author Report Posted December 3, 2020 (edited) Also, In addition to the pulsating as shown in the video above.... The fuel pressure gauge will never go to zero no matter what. This picture is with the engine shut down..... Time for a gauge overhaul? If so any recommendations who can repair or overhaul it? Edited December 3, 2020 by 75_M20F Quote
Immelman Posted December 3, 2020 Report Posted December 3, 2020 Well that doesn't seem right... I had my combo MP/FP overhauled in 2007 at "Sky West Instruments", in Upland, CA. It was $300. I imagine there are quite a few used versions of that gauge available now with so many people going to electronic primary instruments. Quote
carusoam Posted December 4, 2020 Report Posted December 4, 2020 Try turning it 90°... Oops, that didn’t work either... -a- Quote
RobertGary1 Posted December 4, 2020 Report Posted December 4, 2020 It takes some time as I recall for pressure to bleed off. If you go fuel rich after shutdown will it go to zero? 1 Quote
75_M20F Posted December 4, 2020 Author Report Posted December 4, 2020 (edited) 6 hours ago, RobertGary1 said: It takes some time as I recall for pressure to bleed off. If you go fuel rich after shutdown will it go to zero? No, it never reads zero no matter what. It has been removed from the airplane and still reads 8PSI. I am going to have it sent it off for repair. Edited December 4, 2020 by 75_M20F Quote
Marauder Posted December 4, 2020 Report Posted December 4, 2020 No, it never reads zero no matter what. It has been removed from the airplane and still reads 8PSI. I am going to have it sent it off for repair.I suspect you have some sort of obstruction in the fuel line going to the gauge or in the inlet of the gauge.Sent from my iPad using Tapatalk Pro Quote
75_M20F Posted December 5, 2020 Author Report Posted December 5, 2020 15 hours ago, Marauder said: I suspect you have some sort of obstruction in the fuel line going to the gauge or in the inlet of the gauge. Sent from my iPad using Tapatalk Pro The gauge has been shipped off for repair. The braided hose that runs from the cockpit side of the firewall to the fuel pressure gauge... how often is that hose supposed to be replaced? Quote
Marauder Posted December 5, 2020 Report Posted December 5, 2020 The gauge has been shipped off for repair. The braided hose that runs from the cockpit side of the firewall to the fuel pressure gauge... how often is that hose supposed to be replaced?I don’t know if there is a recommended time limit but like the oil pressure line that comes into the cockpit to supply that gauge, if it has been in there for more than 10 years, I would not hesitate replacing it. I suspect many are in there for the lifetime of the plane.I have a friend with a J model and the fuel pressure line actually leaked onto the feet of his passenger.Sent from my iPad using Tapatalk Pro 1 Quote
carusoam Posted December 5, 2020 Report Posted December 5, 2020 Concurrent discussion anyone? Get rid of liquid lines entering the cabin... when able. -a- Quote
PT20J Posted December 6, 2020 Report Posted December 6, 2020 I’d replace it with a teflon hose that has no life limit. Might want to replace all the engine hoses if they are not teflon and are older than 5 years. Quote
jetdriven Posted December 6, 2020 Report Posted December 6, 2020 I ripped out the factory mechanical oil pressure gauge, and installed an electronic oil pressure gauge from the 1980 model, and then got the transducer as well, and wired it up. 3 Quote
75_M20F Posted January 7, 2021 Author Report Posted January 7, 2021 (edited) OK, disconnected both ends of the line that runs from the fuel pressure gauge to the servo and blew it out with compressed air. Also removed and replaced the line from the firewall to the back of the gauge with a new hose. Also, during this the gauge was stuck on 5PSI, so I sent it out to be overhauled also. The shop reported back that the bellows in the gauge had fuel in it..... Unfortunately, the fuel pressure gauge is still pulsating just the same as before.... So what else can it be causing the pulsating? Fuel pump? Edited January 7, 2021 by 75_M20F Quote
carusoam Posted January 7, 2021 Report Posted January 7, 2021 Fuel pressure gauges get installed with a snubber... Some times the gauge has an integral snubber... The snubber acts like a muffler for the pressure noise that occurs naturally in the line... Essentially it is a tiny calibrated hole that allows air to pass back and forth through... Installing the gauge properly requires following a procedure to make sure the right amount of air is at the end of the tube... Not too much or too little... This topic comes up randomly when people either install or change a fuelP sensor... Bob went through a bunch of trouble when he first installed a JPI930 in his ship (Gypsy Rose)... The snubber is often referenced in the parts catalog... (?) PP thoughts and memories of Bob’s posts... Best regards, -a- 1 Quote
75_M20F Posted January 7, 2021 Author Report Posted January 7, 2021 9 minutes ago, carusoam said: Fuel pressure gauges get installed with a snubber... Some times the gauge has an integral snubber... The snubber acts like a muffler for the pressure noise that occurs naturally in the line... Essentially it is a tiny calibrated hole that allows air to pass back and forth through... Installing the gauge properly requires following a procedure to make sure the right amount of air is at the end of the tube... Not too much or too little... This topic comes up randomly when people either install or change a fuelP sensor... Bob went through a bunch of trouble when he first installed a JPI930 in his ship (Gypsy Rose)... The snubber is often referenced in the parts catalog... (?) PP thoughts and memories of Bob’s posts... Best regards, -a- Hello, My bird has the older setup. A fuel line that runs from the pressure gauge out to the servo. I cleaned the entire line out and sent the gauge out for overhaul as it was stuck on 5 PSI. So, I don't know where this snubber would be? Quote
carusoam Posted January 7, 2021 Report Posted January 7, 2021 The snubber is often integral with the gauge... or mounted between the gauge and the pressure line... IE as close as possible to the gauge... Done electronically, an averaging function is often used to keep the numbers from flipping often... Best regards, -a- Quote
Yetti Posted January 8, 2021 Report Posted January 8, 2021 On 12/5/2020 at 8:31 AM, 75_M20F said: The gauge has been shipped off for repair. The braided hose that runs from the cockpit side of the firewall to the fuel pressure gauge... how often is that hose supposed to be replaced? It has 100LL fuel in it. It is above your feet. If it leaks where would it end up. Braided stainless is the only answer. Or better yet. Wires and transducer that sits on the other side of the FireWall 2 Quote
