Lionudakis Posted October 30, 2020 Report Posted October 30, 2020 I just replaced my first Gill sealed after 5 years (in TX) with another Gill. My Concorde lasted 4 , and the previous that was installed when I bought plane was in it for 3 . With the jump in cost of Concordes, my supplier said they had good results with the Gills, so I tried it. No complaints Quote
N201MKTurbo Posted October 30, 2020 Report Posted October 30, 2020 I won a free Gill sealed battery a few years ago at the Maintenance Symposium. It is still going strong. Quote
1964-M20E Posted April 9, 2021 Report Posted April 9, 2021 Well I'm getting ready to get a new battery for mine. I've had the Gill 7035-28 in my plane for 4 years now. Yesterday's start the prop seemed slow. Quote
cctsurf Posted April 10, 2021 Report Posted April 10, 2021 On 4/9/2021 at 7:29 PM, 1964-M20E said: Well I'm getting ready to get a new battery for mine. I've had the Gill 7035-28 in my plane for 4 years now. Yesterday's start the prop seemed slow. Expand Have you had it on a float charger or just sitting? How often do you fly? I've found that float chargers extend battery life significantly. Quote
A64Pilot Posted April 10, 2021 Report Posted April 10, 2021 (edited) Concorde also makes Lifeline batteries, they are not aviation batteries, they are AGM deep cycle batteries, and for all intents and purposes pretty much identical to the Aircraft Concorde. ‘They have by far the absolute best, most comprehensive battery manual in existence, believe it or not but their AGM batteries do best when the battery is allowed to accept all the charge amps you can feed it. As long as the voltage is correct, you cannot push too many amps into one, the battery will only accept what it can handle, as it’s SOC or state of charge increase, acceptance rate will decrease. ‘So if you have a big ole powerful charger, as long as it’s voltage is correct, you can’t push too many amps into a Concorde battery. However if it’s voltage is too high, of course you can. ‘Anyway, sit down and do some reading, as I said this is by way far away the best, most comprehensive battery manual there is, especially for AGM’s http://lifelinebatteries.com/wp-content/uploads/2015/12/6-0101-Rev-E-Lifeline-Technical-Manual.pdf One of the required checks during annual is to determine the reserve capacity of a battery, although it’s seldom done, but if you fly IFR much, you may want to ensure it’s done, cause once that alternator or voltage regulator quits, it’s the reserve capacity of the battery that’s going to get you down safely. I wish battery desulphators worked, but they don’t. About the only way to partially recover from sulphation is an equalization charge, how to do it is in this manual. Lifeline I believe calls it a conditioning charge, but most people refer to it as a equalization charge. ‘The Godber family owns and runs Concorde battery, they are a US company, in the US that employees US citizens and manufactures in the US. To some that may be important. ‘I had my bad Gill experience. almost cost me a bundle, I won’t make that mistake again, but to be honest it was a Gill wet cell, not an AGM Edited April 10, 2021 by A64Pilot Quote
jamesm Posted April 10, 2021 Report Posted April 10, 2021 Looks like Gill finally added the Mooney M20C to the PMA/STC list. I remember many many years ago when I noticed the G-35 battery didn't have the M20C on the STC/PMA list they had the M20B , M20D, M20E, M20F, M20G but no M20C. I called them up ask why, I don't remember their exact answer but they seem pretty determined not to change their STC/PMA paper work on their end. I always thought that was weird to leave of the M20C one the most produced Mooney models off the list. Good for them they Added the M20C model on the PMA/STC list for the 7035-28 model . Though could have done better in their model number scheme. Quote
carusoam Posted April 10, 2021 Report Posted April 10, 2021 Great example of the Gill Sales Prevention Team at work! Sounds like they were trying to help you out. -a- Quote
1964-M20E Posted April 11, 2021 Report Posted April 11, 2021 On 4/10/2021 at 9:09 PM, cctsurf said: Have you had it on a float charger or just sitting? How often do you fly? I've found that float chargers extend battery life significantly. Expand no float charger but I do fly often usually once a week. This instance I had just flown to Houston several days earlier. Quote
A64Pilot Posted April 11, 2021 Report Posted April 11, 2021 float chargers if they are at the correct voltage for an AGM do help, but unlike automobiles which may have significant dark current, we have a master relay that disconnects everything except the keep alive power for a clock, and apparently in some models the interior light, so our batteries shouldn’t run down much. ‘I believe the self discharge rate for an AGM is about 3% per month, but if you don’t fly often, a good battery tender is a good thing to have. Quote
