McMooney Posted September 2, 2020 Report Posted September 2, 2020 (edited) Hello Mooneyspace, my mechanics noticed the fuel pressure for my mooney rarely budges from approx 25psi; only changes when off or the electric fuel pump is on( 27 psi ). is this the correct behavior? I've always assumed it was normal. Edited September 2, 2020 by McMooney
carusoam Posted September 2, 2020 Report Posted September 2, 2020 Hey McM! Sounds good to me... We want the electric FP to do the same job as the mechanical pump, in case one fails... At the same time, when using the electric pump... we don’t want it to over supply the engine... Does your FuelP have a green arc on it? Does the needle stay within the green arc? Some new fuel pumps came out recently, that were over pressuring the fuel by a few psi... there is a solution for that too... PP thoughts only, not a mechanic... Best regards, -a-
McMooney Posted September 2, 2020 Author Report Posted September 2, 2020 2 minutes ago, carusoam said: Hey McM! Sounds good to me... We want the electric FP to do the same job as the mechanical pump, in case one fails... At the same time, when using the electric pump... we don’t want it to over supply the engine... Does your FuelP have a green arc on it? Does the needle stay within the green arc? Some new fuel pumps came out recently, that were over pressuring the fuel by a few psi... there is a solution for that too... PP thoughts only, not a mechanic... Best regards, -a- Yes, stays within the green arc. The mechanic seems to think the fuel pressure should vary a bit more and is suspect of the gauge.
carusoam Posted September 2, 2020 Report Posted September 2, 2020 50 year old gauges can benefit from getting OH’d every half century or so... ? FF instruments do a good job of supply back-up info... JPI 900s and the like are always something to consider for a nice forever plane.... Standby for other MSers with a more direct experience... PP thoughts only... Best regards, -a-
RLCarter Posted September 2, 2020 Report Posted September 2, 2020 Mine was about the same, installed a new mechanical fuel pump and now it’s at the top of the green and stays there. Needle might wiggle some with RPM or Boost pump on, but it isn’t much 1
charlesual Posted September 2, 2020 Report Posted September 2, 2020 Hey McM! Sounds good to me... We want the electric FP to do the same job as the mechanical pump, in case one fails... At the same time, when using the electric pump... we don’t want it to over supply the engine... Does your FuelP have a green arc on it? Does the needle stay within the green arc? Some new fuel pumps came out recently, that were over pressuring the fuel by a few psi... there is a solution for that too... PP thoughts only, not a mechanic... Best regards, -a- Mine stays at the top of the green. Can/Should that be adjusted?Sent from my iPhone using Tapatalk
Hank Posted September 2, 2020 Report Posted September 2, 2020 I'm happy if the fuel pressure in my C stays in the green. Never heard that a constant or near-constant fuel pressure was bad, I always thought that was the goal . . . .
takair Posted September 3, 2020 Report Posted September 3, 2020 Mine sits around 25 almost all the time. Boost pump might bump it up a little, but you have to be staring at it to notice. As long as you are in the green it’s good. 1
J0nathan225 Posted September 3, 2020 Report Posted September 3, 2020 8 minutes ago, takair said: Mine sits around 25 almost all the time. Boost pump might bump it up a little, but you have to be staring at it to notice. As long as you are in the green it’s good. same 25-26 on the EDM 900. 23ish on the analog.
Hank Posted September 3, 2020 Report Posted September 3, 2020 18 minutes ago, J0nathan225 said: same 25-26 on the EDM 900. 23ish on the analog. Ya'll and your high powered, fuel injected engines! Fuel pressure redline in my C is 6 psi . . . . Generally 2 or less in cruise, sometimes 1/2 psi. 1
carusoam Posted September 3, 2020 Report Posted September 3, 2020 Green is good... Outside the green is not always terrible, but can lead to other challenges down the line... Best regards, -a-
outermarker Posted September 4, 2020 Report Posted September 4, 2020 Ok, I'll ask a dumb question. Can damage be caused if you forget to turn off the fuel pump and make a cross country (an hour or more) flight? How does the fuel servo handle the extra fuel pressure over the engine driven pump pressure? You are still going to lean the mixture for whatever altitude you are cruising at so I would think the engine won't see a difference.
RLCarter Posted September 4, 2020 Report Posted September 4, 2020 2 minutes ago, outermarker said: Ok, I'll ask a dumb question. Can damage be caused if you forget to turn off the fuel pump and make a cross country (an hour or more) flight? How does the fuel servo handle the extra fuel pressure over the engine driven pump pressure? You are still going to lean the mixture for whatever altitude you are cruising at so I would think the engine won't see a difference. Extra fuel pressure not a big deal, electric fuel pump is not for continuous use, so may or may not make the trip
Ragsf15e Posted September 5, 2020 Report Posted September 5, 2020 On 9/1/2020 at 8:18 PM, McMooney said: Hello Mooneyspace, my mechanics noticed the fuel pressure for my mooney rarely budges from approx 25psi; only changes when off or the electric fuel pump is on( 27 psi ). is this the correct behavior? I've always assumed it was normal. Mine is exactly the same at 28psi. I think you’re good.
Ragsf15e Posted September 5, 2020 Report Posted September 5, 2020 8 hours ago, outermarker said: Ok, I'll ask a dumb question. Can damage be caused if you forget to turn off the fuel pump and make a cross country (an hour or more) flight? How does the fuel servo handle the extra fuel pressure over the engine driven pump pressure? You are still going to lean the mixture for whatever altitude you are cruising at so I would think the engine won't see a difference. Probably not great for fuel pump, however, not gonna hurt the engine.
McMooney Posted September 5, 2020 Author Report Posted September 5, 2020 8 hours ago, outermarker said: Ok, I'll ask a dumb question. Can damage be caused if you forget to turn off the fuel pump and make a cross country (an hour or more) flight? How does the fuel servo handle the extra fuel pressure over the engine driven pump pressure? You are still going to lean the mixture for whatever altitude you are cruising at so I would think the engine won't see a difference. I have NEVER done this
carusoam Posted September 11, 2020 Report Posted September 11, 2020 1k’ agl... Second check of... 1) Fuel pump off 2) Flaps up 3) gear up Because every now and then... some distraction happens. One of these things gets left in the wrong position... One kills the pump.... the next causes cracks in the sub spar.... The third cause confusion when you put the gear up trying to land... That first year can be tough on the Mooney... PP thoughts only, not a CFI... Best regards, -a- 1
RobertGary1 Posted September 12, 2020 Report Posted September 12, 2020 Mine used to vary a bit. Lycoming shipped my new engine with a new pump and now it’s always at the top of the green. -Robert
J0nathan225 Posted September 12, 2020 Report Posted September 12, 2020 On 9/10/2020 at 9:55 PM, carusoam said: 1k’ agl... Second check of... 1) Fuel pump off 2) Flaps up 3) gear up Because every now and then... some distraction happens. One of these things gets left in the wrong position... One kills the pump.... the next causes cracks in the sub spar.... The third cause confusion when you put the gear up trying to land... That first year can be tough on the Mooney... PP thoughts only, not a CFI... Best regards, -a- I forgot the pump once. I amended to doing a ~1k and double check once I level off for cruise like above. 1
oldguyscanfly Posted September 12, 2020 Report Posted September 12, 2020 My 65 E is 26 psi fuel pump off, 27-28 fuel pump on. Doesn't vary much.
EricJ Posted September 12, 2020 Report Posted September 12, 2020 On 9/4/2020 at 10:03 AM, outermarker said: Ok, I'll ask a dumb question. Can damage be caused if you forget to turn off the fuel pump and make a cross country (an hour or more) flight? How does the fuel servo handle the extra fuel pressure over the engine driven pump pressure? You are still going to lean the mixture for whatever altitude you are cruising at so I would think the engine won't see a difference. It depends on the pump. I think most of the original pumps were not rated for continuous use, but iirc some of them are after overhaul. You could find out what you have installed and the overhaul status, as it might make a difference.
