tigers2007 Posted August 11, 2019 Report Posted August 11, 2019 LIMITED stock. They already sold out a similar product. WORX WG629.2 Hydroshot 20V PowerShare Cordless Portable Power Cleaner https://ebay.us/iA8kcR Is $35.99 after the $4 discount applied during checkout. This comes with a battery and charger too. It should also come with a hose adapter to pull water from a bucket or bottle. Great for the hangar! I'm going to use it to help clean the crap in the wheel wells. Reviews are sketchy but it should be weak enough to not blast paint nor force water into tight crevices.
tigers2007 Posted August 11, 2019 Author Report Posted August 11, 2019 Looks like you can get a "short rod adapter" that accepts the universal power washer tips for around $10-13 too.
tigers2007 Posted August 28, 2019 Author Report Posted August 28, 2019 This thing works great! The reviews don’t give it justice. For MS purposes, thing thing is gold. Has plenty of pressure to blast away grime. The included accessories work great. Note that I did buy the short extension piece as show in the photos. The Worx kit does come with the multi-angle spray tip. Sent from my iPhone using Tapatalk
