Could somebody take a picture with throttle fully retarded of the safety switch and the slot as to how the switch actuates
its just under pilots right knee...very accessible
I found this a bit tricky to adjust. As shown in the picture, the "step" is really where the roller on the microswitch arm rides up on the cable swedge.  If you set the switch too far toward the cable, it hangs up a bit on the edge of the swedge when you close the throttle. If you set it two far out, the switch doesn't actuate. And of course you have to adjust this while standing on your head.:)
