KB68M20F Posted February 28, 2019 Report Posted February 28, 2019 Hi Guys, I’m considering replacing the 50 year old RG58 coax in my aircraft while doing an ADS B upgrade. Has anyone ever had experience with replacing the coax in the vertical stab? Specifically I’m not sure if the holes in the ribs in the vertical stabilizer will allow a pull through of new coax without taking the tail apart. Mine appears to have a balun also, which is double the size of normal coax. Any ideas? Thanks! Quote
1964-M20E Posted February 28, 2019 Report Posted February 28, 2019 I replaced the cable from the tail bulkhead to the cockpit but I do not know about getting a new one in the vertical portion. My problem turned out to be a loose connection on the back of the radio. A long time chasing that ghost and cursing when I could not picu0p a VOR within 15 miles. Quote
Marauder Posted February 28, 2019 Report Posted February 28, 2019 5 minutes ago, KB68M20F said: Hi Guys, I’m considering replacing the 50 year old RG58 coax in my aircraft while doing an ADS B upgrade. Has anyone ever had experience with replacing the coax in the vertical stab? Specifically I’m not sure if the holes in the ribs in the vertical stabilizer will allow a pull through of new coax without taking the tail apart. Mine appears to have a balun also, which is double the size of normal coax. Any ideas? Thanks! Not sure if your antenna mount is riveted or has screws holding it on. When you disassemble, the easiest way is to pull the new RG-400 through using the old RG-58 as the wire puller. Strip back several inches of both old and new wires and physically wrapped them together (like a lineman connection) so that the total attachment is less than the width of the outer sheathing. I would then wrap it in electrical tape and pull the new wire up through the tail. If that fails, the other option is to use an electrician's fish tape and do it that way. I would recommend using RG-400. It is the standard today. 1 Quote
jetdriven Posted February 28, 2019 Report Posted February 28, 2019 I Cut, crimped, and pulled RG400 thru the whole airplane. But the piece that went from the base of the tail up to the what’s now blade antennas, I left in there. Quote
Marauder Posted February 28, 2019 Report Posted February 28, 2019 33 minutes ago, jetdriven said: I Cut, crimped, and pulled RG400 thru the whole airplane. But the piece that went from the base of the tail up to the what’s now blade antennas, I left in there. Chicken! I have the permanent scars from that activity. Quote
DXB Posted March 1, 2019 Report Posted March 1, 2019 No idea what you guys are talking about. Is that like some kinda old timey GPS? 1 Quote
Prior owner Posted March 1, 2019 Report Posted March 1, 2019 I just went through this with my ‘64 D model. The cable goes from the VOR antenna down the left side of the vertical stabilizer (at least mine did). You have to remove the left side root fairing on the horizontal stab to access the cable clamps that are attached to the aft side of the fuselage bulkhead, under the horizontal stab. I replaced the VOR antenna at the same time with one that has a modern internal balun. Not sure what your ‘68 will have installed. Similar to what others have done, I cut my old cable at the bottom where it goes into the fuselage bulkhead (near the tail hinge) and joined it with the RG400 cable with duct tape and then pulled the RG400 up from the antenna. We also installed a new bulkhead fitting with BNC fittings on both sides. The hardest part was accessing the bolt for the upper clamp on the bulkhead. Might have been easier to try to simply pull the tail of the RG400 through the old clamp without removing the clamp. Quote
Yetti Posted March 2, 2019 Report Posted March 2, 2019 (edited) If you have wisker antenna. In the vert stab is a Balun not straight coax. Edited March 2, 2019 by Yetti Quote
Prior owner Posted March 2, 2019 Report Posted March 2, 2019 4 hours ago, Yetti said: If you have wisker antenna. In the vert stab is a Balun not straight coax. Here is the one I pulled out of mine...I replaced it with a modern VOR antenna 1 Quote
EricJ Posted March 2, 2019 Report Posted March 2, 2019 9 hours ago, PilotCoyote said: Here is the one I pulled out of mine...I replaced it with a modern VOR antenna ... Durp. I'm guessing that's the "splitter" for the nav/gs? Will be good to get that out of there. Quote
Prior owner Posted March 2, 2019 Report Posted March 2, 2019 No that’s the balun....not a splitter. Newer VOR antennas have a miniature balun inside the antenna base. The the old antennas have a long length of wires that are joined together to tune it. Quote
Yetti Posted March 2, 2019 Report Posted March 2, 2019 https://www.aircraftspruce.com/catalog/avpages/rami15-97-6.php?gclid=CjwKCAiA8OjjBRB4EiwAMZe6y5HxpUl0lXvy1jcl3wxO926J_2JPumJdlQ8BMWCpUHuIS8Lfamxj5BoC-m0QAvD_BwE 1 Quote
EricJ Posted March 2, 2019 Report Posted March 2, 2019 There may be a balun in there somewhere, but whatever it is needs to be replaced. Quote
Yetti Posted March 2, 2019 Report Posted March 2, 2019 14 hours ago, PilotCoyote said: Here is the one I pulled out of mine...I replaced it with a modern VOR antenna Like what? Quote
Prior owner Posted March 3, 2019 Report Posted March 3, 2019 (edited) 19 hours ago, Yetti said: Like what? This one here- Comant Nav Antenna I mis-spoke when I said “modern”... I meant only that it doesn’t have an external balun. Edited March 3, 2019 by PilotCoyote 1 Quote
Prior owner Posted March 3, 2019 Report Posted March 3, 2019 22 hours ago, Yetti said: https://www.aircraftspruce.com/catalog/avpages/rami15-97-6.php?gclid=CjwKCAiA8OjjBRB4EiwAMZe6y5HxpUl0lXvy1jcl3wxO926J_2JPumJdlQ8BMWCpUHuIS8Lfamxj5BoC-m0QAvD_BwE I had no idea they still sold these! Quote
Yetti Posted March 3, 2019 Report Posted March 3, 2019 or solder up your own. Now I am wondering if my 75 has the internal balun. Quote
Jim Peace Posted March 4, 2019 Report Posted March 4, 2019 suggestions on cleaning the antenna while its in place or what to coat it with to prevent surface staining or corrosion? Quote
KB68M20F Posted March 28, 2019 Author Report Posted March 28, 2019 Hi guys, Just as my fellow Mooney pilots advised on this post, I pulled new RG 400 from the base of the horizontal stabilizer to the top of it by attaching the new to the old. I put the two ends together, applied a piece of heat shrink, then wrapped one side with .020 safety wire, brought a piece across to the other side and wrapped it. Then I put some electrical tape over the joint to make it smooth, tested the strength and pulled it through. There may be grommets in the vertical stab ribs but it went through just fine. The hardest part was tightening the nut on the upper AN742 clamp that holds the coax in place. It was a real ball buster with difficult angles. I also installed a new cat whisker antenna with an internal balun and BNC connector. 2 1 Quote
carusoam Posted March 28, 2019 Report Posted March 28, 2019 Nice follow up report, KB! Go MS! Best regards, -a- Quote
