Service center thinks my starter adapter is going bad. 1999 Mooney Eagle w/ IO 550. Has anyone had this repaired. They recommnend sending it out for rebuild ( $850.00 - $1400.00) and labor to remove and reinstall (4 hours). Does this sound about right? Don? anyone?
yeah,welcome to continentals...ive done 2 of them in past years....they have to send out to machine shop to machine down undersized (010 as i recall).You donot mention engaging starter and having a delay before the prop rotates.What symptons are you experiencing???sinc kp couch
Starter engages but can not pull engine through compression stroke. It just seems too weak. After 2 or 3 turns of the key it pulls through the "tough spot" and starts right up. When hot it will not pull though at all, takes 10 or 15 tries.
yep..those are the symptons all right,,,I have used Divco in tulsa ok for the machine work...I under stand you can do this a couple times before you replace complete assembly from continental.I do not believe skytec has a stc for starter....goodluck...kpc
oh,i forgot to mention...is that soon the starter adaptor will no longer engage at all and this is one engine you donot want to handprop..kpc
I had a guy hand prop me in an IO-520 in a Bonanza I was flying once.  You should have seen that, and no, I wouldn't attempt it ever.
Yep, MSC listened to it for 2 seconds and said thats what it was. Sent out for rebuild, should be back in the air in a few days. Thanks for all the info. This is a great site.
Bruce
