cliffy Posted August 15, 2019 Report Posted August 15, 2019 With two magnetos you need to ground the one for starting Get the bar and install it 1
jkarch Posted August 15, 2019 Report Posted August 15, 2019 Where do I get that bar from? Right now all I have is a jumper. It’s basically busbar material but the link distance is custom right? There’s no PN for that which is why I have a short 16 AWG wire link between two pidg lugs.
cliffy Posted August 15, 2019 Report Posted August 15, 2019 You can probably call any magneto repair shop and order it but the wire jumper should work just fine if it is made well and secure. 1 1
jkarch Posted August 15, 2019 Report Posted August 15, 2019 You’d be surprised how hard these things are to find but that wire jumper is pretty solid!
McMooney Posted August 15, 2019 Report Posted August 15, 2019 On 9/22/2018 at 8:32 PM, LANCECASPER said: Before I spent $500 for a new switch I would be tempted to get an EA-15000. http://electroair.net/switchPanel.html think this'll work with a surefly?
Guest Posted August 15, 2019 Report Posted August 15, 2019 10 hours ago, cliffy said: With two magnetos you need to ground the one for starting Get the bar and install it Unless the engine has dual impulse couplings. Clarence
cliffy Posted August 15, 2019 Report Posted August 15, 2019 3 hours ago, M20Doc said: Unless the engine has dual impulse couplings. Clarence Do any Mooneys have dual impulse couplings? :-) I've never seen one.
EricJ Posted August 15, 2019 Report Posted August 15, 2019 1 hour ago, cliffy said: Do any Mooneys have dual impulse couplings? :-) I've never seen one. One of the advantages of the dual mag (D) is that the impulse coupler can drive both sides. I think this is where the rewiring issues with the ignition switch come from.
