Hank Posted February 21, 2018 Report Posted February 21, 2018 4 hours ago, ragedracer1977 said: I’ve heard an IA object to that specific topic. Red is only for “danger”, green for “things are good to go”, and blue for “it’s on”. Hmmmm . . . . The only cockpit illumination my C left tne factory with was two red lights on the ceiling and a red light shining on the clock. Oh, and an amber light for "Gear Up" and a green light for "Gear Down" along with the white light shining on the floor indicator, which is painted red and green inside the window. Quote
bob865 Posted February 21, 2018 Report Posted February 21, 2018 20 hours ago, Marauder said: The red lights are an add on? I don't have that switch on my 75. I have the switch in my '75 E. Quote
Marauder Posted February 21, 2018 Report Posted February 21, 2018 I have the switch in my '75 E. Wonder if it was as Yetti mentioned an option and if it wasn’t when was it removed. Where exactly is it located? Quote
bob865 Posted February 21, 2018 Report Posted February 21, 2018 1 minute ago, Marauder said: Wonder if it was as Yetti mentioned an option and if it wasn’t when was it removed. Where exactly is it located? Just below the throttle quadrant. The three knobs to the switch's left are the dimmers. One for right panel, one of left panel, and one for gauge backlight. Quote
ragedracer1977 Posted February 21, 2018 Report Posted February 21, 2018 3 hours ago, Hank said: Hmmmm . . . . The only cockpit illumination my C left tne factory with was two red lights on the ceiling and a red light shining on the clock. Oh, and an amber light for "Gear Up" and a green light for "Gear Down" along with the white light shining on the floor indicator, which is painted red and green inside the window. I was referring to the annunciator panel, well he was Quote
Marauder Posted February 21, 2018 Report Posted February 21, 2018 Just below the throttle quadrant. The three knobs to the switch's left are the dimmers. One for right panel, one of left panel, and one for gauge backlight. Definitely looks like factory installed. I don’t have this. I wonder how they fit both red and white bulbs in that small area? Sent from my iPad using Tapatalk Pro Quote
mooniac15u Posted February 21, 2018 Report Posted February 21, 2018 8 hours ago, carusoam said: 15U, The bulb that Bonal is discussing, came out of My M20C so easily... no tools were required... it looked like it was made from an old bullet casing... Left over WWII machinery redeployed...? I assumed it was on the list of things that can be changed by the pilot... In initial training, the CFI covers the, what to do if this bulb goes out... what bulbs can be replaced by others in the panel. Along with the rotate this knob to open and close the iris... a fact that gets lost over time, years of not flying at night... Anybody just find out that light fixture has an iris in it? (Twist to dim, untwist to brighten) Somebody new to their Mooney might appreciate this... Best regards, -a- I recognized the indicator light from the picture. I owned an M20D before my current M20J and it had those indicator lights. The simplicity of a task does not seem to have any bearing on whether the FAA thinks a pilot should be allowed to do it. For example, changing spark plugs is far more complex (and potentially riskier) than unscrewing a light bulb. But, as far as I can tell, spark plugs are on the list and interior bulbs are not. 1 Quote
neilpilot Posted February 21, 2018 Report Posted February 21, 2018 3 hours ago, Hank said: an amber light for "Gear Up" and a green light for "Gear Down" Interesting, since when I acquired my 65C the "Gear Up" light was red, not amber. Coincidentally the red lens fell out and was never found, and I replaced that fixture with an amber light. Now I'm no longer concerned that I'm the only C with an amber Gear Up light. Quote
Andy95W Posted February 21, 2018 Report Posted February 21, 2018 2 minutes ago, mooniac15u said: The simplicity of a task does not seem to have any bearing on whether the FAA thinks a pilot should be allowed to do it. For example, changing spark plugs is far more complex (and potentially riskier) than unscrewing a light bulb. But, as far as I can tell, spark plugs are on the list and interior bulbs are not. It took re-reading FAR 43 Appendix A, but I agree- the FAA hasn't updated its list to include interior lights, or really any other light bulbs besides landing and position (nav) lights: ---------------------------------- (17) Replacing bulbs, reflectors, and lenses of position and landing lights. ---------------------------------- It's a darn good thing the hangar fairies are so good at it! 1 Quote
Guest Posted February 21, 2018 Report Posted February 21, 2018 So if your Gear position light bulb burns out in flight you’re not allowed to take the one out of the compass and replaced it? God bless the FAA for their logic. Clarence Quote
neilpilot Posted February 21, 2018 Report Posted February 21, 2018 10 minutes ago, Andy95W said: (17) Replacing bulbs, reflectors, and lenses of position and landing lights. ---------------------------------- It's a darn good thing the hangar fairies are so good at it! When I posted above, I should have pointed out that the lamp I changed indicated the POSITION of my landing gear. 2 1 Quote
bob865 Posted February 21, 2018 Report Posted February 21, 2018 1 hour ago, Marauder said: Definitely looks like factory installed. I don’t have this. I wonder how they fit both red and white bulbs in that small area? Trade you my red/white switch for your panel? Seems like an even trade to me since I'm having the G5 put in this week. 1 Quote
Hank Posted February 21, 2018 Report Posted February 21, 2018 (edited) 1 hour ago, neilpilot said: Now I'm no longer concerned that I'm the only C with an amber Gear Up light. It was like this when I bought the plane in 2007 . . Edited February 21, 2018 by Hank Quote
mooniac15u Posted February 21, 2018 Report Posted February 21, 2018 1 hour ago, M20Doc said: So if your Gear position light bulb burns out in flight you’re not allowed to take the one out of the compass and replaced it? God bless the FAA for their logic. Clarence If your gear down light burns out it has an impact on safety of flight which could reasonably be considered an emergency. During an emergency a pilot is authorized to deviate from the regs to the extent necessary to deal with the emergency. Quote
mooniac15u Posted February 21, 2018 Report Posted February 21, 2018 I'm not trying to suggest that the current rules make sense, just that it's not actually legal under the current rules for a pilot to replace these bulbs. Perhaps we could convince EAA/AOPA to put some pressure on the FAA to revise/expand the preventive maintenance list. Quote
Marauder Posted February 21, 2018 Report Posted February 21, 2018 Trade you my red/white switch for your panel? Seems like an even trade to me since I'm having the G5 put in this week. Too funny. That is actually an old photo. This is what it looks like now.Sent from my iPad using Tapatalk Pro 1 Quote
65MooneyPilot Posted February 21, 2018 Report Posted February 21, 2018 Go to: cockpitlights.com I installed Dave’s lights in my airplane. It is true the old stock dimmer needs to be changed if you want them to dim. I did not change it out. Now that I am older I need more light anyway. Quote
65MooneyPilot Posted February 21, 2018 Report Posted February 21, 2018 Here is a picture of the lights. Quote
65MooneyPilot Posted February 21, 2018 Report Posted February 21, 2018 I also changed the Dome Light with a white light. I can also use is as a cockpit reading light because of its swivel aim ability. Quote
