AaronDC8402 Posted September 1, 2017 Report Posted September 1, 2017 I've been searching for a few days with no luck. Can someone tell me the part number for the rear (white) position bulb for a 1989 M20J? Searching for E7 didn't result in anything helpful. Also, the leads on the bulb were a little corroded, and so was the socket it was in. Is that typical? Quote
mooniac15u Posted September 1, 2017 Report Posted September 1, 2017 In the parts catalog it is part number 34-022-8030-85 but Mooney says that part is no longer available and offers a retrofit kit (part number 940103-501) http://www.mooney.com/en/pdf/Retrofit_Kits.pdf You should probably call LASAR and ask them for a recommendation. Quote
ZFD Posted September 6, 2017 Report Posted September 6, 2017 I also have a 1989 201. I ordered bulbs from spruce but they were the wrong ones. I think there may be an issue with the IPC. After doing some research I found the right one. For my aircraft Whelen bulb A50828 worked fine. There is no corrosion on my socket Quote
