Since we have had this engine overhauled in Sept 2014, she has flown about 150 hours. I have been plagued with push rod seal leaks, and a few minor valve cover seal leaks. These leaks are usually on the left side. Although I see cyl 2 and 4 are both culprits.
Since leaving the overhaul shop I have had push rod seal leaks repaired over 4 times now.
Am I the only one? Should I be calling Continential? Is it possible that people are using cheap aftermarket seals?
If I wanted to see oil on my engine and hangar floor then I would have bought a Stearman or DC-3   :-)
You could be describing at the crankcase or at the cylinder. Especially at the crankcase they need to be coated with DC-4 to prevent leakage - if only oil was used they tend to leak. If at the cylinder make sure the leaky seal is making a good fit. Sometimes the hole is a bit oversize and needs a Al washer to seal it better.
I would have the crankcase pressure checked.  Excess case pressure can cause annoying leaks.  Case pressure should not exceed 4" H2O.
My pushrods do the same on the left, after 4 reseals and using the real seal brand.  It has improved a bit with the newer seals.  Tsio360lb 200 hours smoh late 2014 oh
Minor valve cover leaks too, but those were solved w upgraded gasket covers
Edited by jrwilson
How do you check crankcase pressure and what do you do to lower it?
We use a replacement oil cap with a fitting soldered to it, to that we connect a pressure gauge or an airspeed indicator.  90 mph equals 4" H2O.  High pressure is a indication of a blocked breather vent or high blow by.
Thanks!
I had the same problem on mine. I cleaned and coated with PRC 1422 A1 all around the seal area with a small brush. After 7 years not a drop of leak. For the valve covers gaskets I replaced them with the orange silicone ones. Not a drop. in 7 years.
José
Oil leaks, and a general sense that 140 hours in 10 years is much too low recency of time.  It's apparent that the airplane sits a lot, and the oil slick I found post-flight under the airframe ran as far back as the ADF antenna.  Small wonder the ADF was inoperative...  A conversation with a pre-buy mechanic got a strong recommendation to either get a much lower price or not buy the airplane.  I'm willing to get work done to get an airplane to where I wanted it to be, but it seemed like this plane had immediate problems.
