jkgyr52 Posted March 31, 2017 Report Posted March 31, 2017 HELLO! I am trying to find copies of the Coy Jacob's ModWorks 262 conversion from a 231 to the 262. Specifically I need a copy of the STC for a serial number prior SN: 25-1000. I also need a copy of the AFMS (Approved Flight Manual Supplement). I would appreciate any help! Thanks, Jeff Quote
milotron Posted March 31, 2017 Report Posted March 31, 2017 I can help with the POH supplement. Let me know how you want it conveyed. It is about 4MB. Quote
jkgyr52 Posted March 31, 2017 Author Report Posted March 31, 2017 Milotron, Thanks. Is this the one that is the AFMS with "ModWorks" on the front page? I do have the pages that are the replacement for engine spec's and operation in the normal procedures section. I would appreciate you sending the one I need but don't want to waist your time otherwise. Whatever way is the easiest for you and I am willing to pay whatever it costs. THANK YOU AND SINCERELY Jeff King flyingfalconpllc@gmail.com Quote
milotron Posted March 31, 2017 Report Posted March 31, 2017 I think that is the same that I have, but will send to you regardless. I might have something else in the logs and will email what I find shortly. Quote
jkgyr52 Posted March 31, 2017 Author Report Posted March 31, 2017 Milotron was able to send me the AFMS!!! I STILL NEED THE FIRST PAGE OF THE STC FOR INSTALLING A MB ENGINE IN A 231, HELP Jeff Quote
carusoam Posted March 31, 2017 Report Posted March 31, 2017 (edited) One (two) question(s) for you, Jeff... What are you trying to accomplish? A new conversion, or rehabbing an older conversion, or...? Best regards, -a- Edited April 1, 2017 by carusoam Quote
Andy95W Posted March 31, 2017 Report Posted March 31, 2017 3 hours ago, jkgyr52 said: Milotron was able to send me the AFMS!!! I STILL NEED THE FIRST PAGE OF THE STC FOR INSTALLING A MB ENGINE IN A 231, HELP Jeff Just because there is an STC available doesn't mean that you are authorized to put it on your airplane. STCs are normally issued by aircraft SN, and sold by the STC holder. Some STCs require a specific shop (usually the STC holder) to perform the work. Since an STC exists for the modification, a Field Approval by the FAA would be simplified. Normally, in a case like that, the FAA will ask why you didn't buy the STC in the first place. Quote
jkgyr52 Posted April 1, 2017 Author Report Posted April 1, 2017 Andy, I have the engine installed in my plane, I am just trying to find the STC documentation. Jeff Quote
carusoam Posted April 1, 2017 Report Posted April 1, 2017 (edited) Would checking the FAA records be of assistance? If your plane was modified using the STC, there is probably a whole record for it at the FAA. Use your serial number to find it... did you recently purchase your bird? Did you get all the logs that came with it? PP thoughts only, not an expert on these docs... best regards, -a- Edited April 1, 2017 by carusoam Quote
jkgyr52 Posted April 2, 2017 Author Report Posted April 2, 2017 I have had this plane for 6 years and didn't know about needing a copy of the STC to upgrade to a JPI EDM 900, until now. We could not find the STC in airplane paperwork which is very complete otherwise. Mooney Mart is not around anymore and I found the STC number in FAA search database, but no copies available presently. Someone in the Atlanta FSDO is seeing if a copy can be had from the archives. Thanks for suggestions. Jeff 1 Quote
Marauder Posted April 2, 2017 Report Posted April 2, 2017 I have had this plane for 6 years and didn't know about needing a copy of the STC to upgrade to a JPI EDM 900, until now. We could not find the STC in airplane paperwork which is very complete otherwise. Mooney Mart is not around anymore and I found the STC number in FAA search database, but no copies available presently. Someone in the Atlanta FSDO is seeing if a copy can be had from the archives. Thanks for suggestions. Jeff You can pull the FAA records for your plane and they will send you it on a CD. Might have it there. Someone posted in MooneySpace how to obtain it. Sent from my iPhone using Tapatalk Pro Quote
jkgyr52 Posted April 2, 2017 Author Report Posted April 2, 2017 I have the FAA CD and it is not there. Jeff Quote
Marauder Posted April 2, 2017 Report Posted April 2, 2017 I have the FAA CD and it is not there. Jeff Coy Jacobs is still around. Tried him?Sent from my iPhone using Tapatalk Pro Quote
Andy95W Posted April 2, 2017 Report Posted April 2, 2017 6 hours ago, jkgyr52 said: Andy, I have the engine installed in my plane, I am just trying to find the STC documentation. Jeff 1 hour ago, jkgyr52 said: I have the FAA CD and it is not there. Jeff Yikes. Good luck, please keep us posted. I've seen cases like this work out well, and others are really ugly. I hope yours works out well (and not expensive). Quote
