I took this while flying today.  8,500 feet MSL 22" and 2500RPM in my 75 F Model.  Im new to Mooney's and the EDM700.  The CHT looked higher on the #2 cylinder and the Oil temp was bouncing a bit.  Does anything look troubling to any of you or is this a fairly normal presentation.
148989E7-E455-4926-8EF1-12FF62729F6F.MOVFetching info...
IMG_6523.MOVFetching info...
Expand
I have a 75 F as well. Your cylinder temps are fine. Your higher #2 cylinder temp may be due to the probe used. I would check to see if a gasket type probe is being used on the #2 cylinder. I do think your oil temperature is higher than I ever have seen in my F. I usually don't see above 195. II think the up and down readings are nothing to be concerned with. I would check the manual for your 700 series JPI to make sure it isn't some weird warning indicator. 'm sure the A&Ps on the site can chime in on their thoughts.
The CHT on #4 is down in the range where the lead scavengers in the fuel may not be very effective.  If it is usually in the mid 200s you may have to watch that cylinder for lead deposits.
