air cooled dad Posted August 15, 2016 Report Posted August 15, 2016 What are these two black things on my ceiling? They have power hooked up to them. Can't find anything in the POH and nothing in the maintenance manual. Thanks Jason the new Mooney owner. Lol. (1975 F)
air cooled dad Posted August 15, 2016 Author Report Posted August 15, 2016 My passenger who asked about the doohickeys took this cool pic today. I like the clouds reflecting off the wing!! 3
Guest Mike261 Posted August 15, 2016 Report Posted August 15, 2016 they look like piezo sounders. stall or gear horn maybe? mike
jasona900 Posted August 15, 2016 Report Posted August 15, 2016 Yep.. looks like some sort of warning horn.
Raptor05121 Posted August 15, 2016 Report Posted August 15, 2016 Yep, look like sounders to me. Gear warning and stall makes sense. Mine are under the panel.
TTaylor Posted August 15, 2016 Report Posted August 15, 2016 Yes, in the 75F those are gear and stall warning Piezo electric horns. You should be able to cause the stall warning to go off on the ground by turning on the master switch and manually moving the stall warning vane in the wing.
Guitarmaster Posted August 15, 2016 Report Posted August 15, 2016 Sonalerts. Stall and gear warning. Gear is drivers side Sent from my XT1254 using Tapatalk 1
carusoam Posted August 15, 2016 Report Posted August 15, 2016 Brand name: Sonalert. What it does: piezo electric warning device. They are usually hidden on the other side of the ceiling plastic parts. If you haven't tested them yet. Do so on/and prior to your next flight. Ya? Stall horn requires the power on while you activate the stall vane. Easy to do on the ground... gear horn requires the gear to be up with the throttle out. More of a challenge to do on the ground. See if you can hear an audible difference. You don't want to confuse one with the other. these things are known to age and stop working every twenty to forty years. Looks like somebody made a change. Just verify that they work properly. Best regards, -a- 1
Marauder Posted August 15, 2016 Report Posted August 15, 2016 Let's see the rest of your 75 F. You have some sort of modified overhead light. What other goodies do you have? Sent from my iPad using Tapatalk 1
Marauder Posted August 15, 2016 Report Posted August 15, 2016 And to test the gear horn, pull power back below 12" of MP while flying. Sent from my iPad using Tapatalk
carusoam Posted August 15, 2016 Report Posted August 15, 2016 Close to the ears, they could be kinda loud... -a-
Guest Posted August 15, 2016 Report Posted August 15, 2016 Not to be critical, but you should have heard these sound during your check out in the plane. Clarence
Yetti Posted August 15, 2016 Report Posted August 15, 2016 7 hours ago, Marauder said: Let's see the rest of your 75 F. You have some sort of modified overhead light. What other goodies do you have? Sent from my iPad using Tapatalk I have the same eyeball light
Marauder Posted August 15, 2016 Report Posted August 15, 2016 7 hours ago, Marauder said: Let's see the rest of your 75 F. You have some sort of modified overhead light. What other goodies do you have? Sent from my iPad using Tapatalk I have the same eyeball light Interesting. Wonder if there was a change made during the 75 production run. Mine is an August build and I have a opaque color plastic cover, no eyeball. Sent from my iPad using Tapatalk
Marauder Posted August 15, 2016 Report Posted August 15, 2016 Sonalerts. Stall and gear warning. Gear is drivers side Sent from my XT1254 using Tapatalk The factory install units were Sonalerts. Not sure those are Sonalerts. The Sonalert units installed in our Mooneys weren't screwed in. They have a two piece design that allows the outer ring that screws on. Sent from my iPad using Tapatalk
HRM Posted August 15, 2016 Report Posted August 15, 2016 10 hours ago, air cooled dad said: I like the clouds reflecting off the wing!! So do I! Great idea for the next paint job
Ron McBride Posted August 15, 2016 Report Posted August 15, 2016 My 69f has the same set up on the Sonalerts and eyeball light. Ron
Bob_Belville Posted August 15, 2016 Report Posted August 15, 2016 My gear alert and AOA are wired through the audio panel and the stall is a Sonalert mounted in the glareshield.
air cooled dad Posted August 15, 2016 Author Report Posted August 15, 2016 4 hours ago, M20Doc said: Not to be critical, but you should have heard these sound during your check out in the plane. Clarence For the record I preflight the stall horn every flight. Yes, I hear the sound. The sound even works when I pull the throttle back. I fly with my family onboard. I preflight my plane like their lives depend on it, because they do. Unfortunately my "checkout" in the plane only consisted of the previous owner handing me the keys. Book study, calls to Mooney owning friends, and 15000 hours of experience helped me survive! (Insert sarcasm here) All criticism and knowledge is welcome! No pride and ego in my cockpit. I thought it was coming from the speaker above my head. Now thanks to all of you I know it comes from those little round Spiezo doohickeys next to the speaker. Thank you for all the responses. You are the Wikipedia of all things Mooney! Jason 1
bradp Posted August 16, 2016 Report Posted August 16, 2016 If you have a master warning test button and it is a "chirp chirp chirp" like your gear warning, it comes from the same speaker as the gear warning and can be tested on the ground. One sonalert is solid tone and the other is intermittent.
Yetti Posted August 16, 2016 Report Posted August 16, 2016 14 hours ago, Marauder said: Interesting. Wonder if there was a change made during the 75 production run. Mine is an August build and I have a opaque color plastic cover, no eyeball. Sent from my iPad using Tapatalk Mine is december 74 build with a July 75 flight test
