DrBill Posted August 9, 2016 Report Posted August 9, 2016 Went to go fly today and my mech fuel pressure is 50psi. Was aok on 7/18. This obviously causes rich running and it quits at idle. Any ideas ? This engine had major in Jan and now has less than 20 hrs on it with the fuel system overhauled at same time. Bill
N201MKTurbo Posted August 9, 2016 Report Posted August 9, 2016 (edited) That pressure is set by the spring in the fuel pump. The only thing that I can think of that would make it do that would be high crankcase pressure which would act like a stronger spring in the pump. One other thing would be the shaft in the pump that lifts the diaphragm could be jammed and driving the diaphragm instead of letting the spring push it up. (bad pump) Edited August 9, 2016 by N201MKTurbo
Guest Posted August 9, 2016 Report Posted August 9, 2016 Connect a test gauge to the fuel system to verify the problem first. Clarence
Yetti Posted August 9, 2016 Report Posted August 9, 2016 what device is saying 50 PSI? could be a bad transducer. Check downstream of the pump for blockage. Say the screen at the servo. old or new fuel lines?
DrBill Posted August 11, 2016 Author Report Posted August 11, 2016 The dash fuel pressure gauge shows 50 with mechanical pump (engine running) and properly at 30 with electric pump only (engine off). So tomorrow my A&P and I will try to pull the pump. All new fuel system since had full Overhaul in Jan-Feb. pump is under warranty from engine builder. Was ok on 7/18. and high yesterday, I understand it is a common mode of failure when the mech pump fails. Thanks for all the responses. Bill
DrBill Posted August 12, 2016 Author Report Posted August 12, 2016 engine builder (triad aviation) giving me new pump under warranty. and will help with R&R labor ! YEA! big job to pull pump, will do another day. Bill BTW the fuel pressure on mech pump is governed by return spring under diaphragm. 1
carusoam Posted August 13, 2016 Report Posted August 13, 2016 There is another thread discussing fuel pressure related to a C. Typical range for the O360 is only 2-6 psi or so... looks like somebody had received an E's pump for their carb'd engine. Sharing similar story, -a-
DrBill Posted August 13, 2016 Author Report Posted August 13, 2016 I just read that thread and agree that he's got an electric pump for an injected engine. Bill
N201MKTurbo Posted August 14, 2016 Report Posted August 14, 2016 FWIW, if you want to void the warrantee on the pump, just chip the sealant off the pressure regulator, remove the little plate that says not to adjust and adjust the pressure to whatever you want....
Guest Posted August 14, 2016 Report Posted August 14, 2016 9 hours ago, N201MKTurbo said: FWIW, if you want to void the warrantee on the pump, just chip the sealant off the pressure regulator, remove the little plate that says not to adjust and adjust the pressure to whatever you want.... and hammer out a new data plate to "correct" the part number. Or just bend the needle on the gauge to a more pleasing value. Clarence
DrBill Posted August 18, 2016 Author Report Posted August 18, 2016 On 8/14/2016 at 5:54 AM, M20Doc said: and hammer out a new data plate to "correct" the part number. Or just bend the needle on the gauge to a more pleasing value. Clarence The main problem is the engine runs like crap with the high pressure and is difficult to stop ! Mag drop went from 25 before to 110 after pressure change. So I'm looking forward to the lower pressure to get back in the air. Bill
DrBill Posted September 6, 2016 Author Report Posted September 6, 2016 M20Doc was right. Today we went out to replace pump and I said lets verify problem first. So I started it up and sure enough c 45psi. My A&P walked around and said no smoke, should be smoking at that pressure so we drove around the a/p for a while and back to hangar shut it down. DUH 15 PSI at shutdown. So he grabs a couple of wrenches and dives under the panel.. "WHATS IT NOW" he yells, "15 " I say. "Disconnected" he says. SO saves us a ton of work, he pulls the gauge and now i need to send for repair. ANY SUGGESTIONS ? thanks. BILL
eman1200 Posted September 7, 2016 Report Posted September 7, 2016 On 8/14/2016 at 5:54 AM, M20Doc said: and hammer out a new data plate to "correct" the part number. Or just bend the needle on the gauge to a more pleasing value. Clarence The main problem is the engine runs like crap with the high pressure and is difficult to stop ! Mag drop went from 25 before to 110 after pressure change. So I'm looking forward to the lower pressure to get back in the air. Bill Bill, wouldn't this indicate an actual issue and not "just a gauge issue"?
mooniac15u Posted September 7, 2016 Report Posted September 7, 2016 20 hours ago, DrBill said: M20Doc was right. Today we went out to replace pump and I said lets verify problem first. So I started it up and sure enough c 45psi. My A&P walked around and said no smoke, should be smoking at that pressure so we drove around the a/p for a while and back to hangar shut it down. DUH 15 PSI at shutdown. So he grabs a couple of wrenches and dives under the panel.. "WHATS IT NOW" he yells, "15 " I say. "Disconnected" he says. SO saves us a ton of work, he pulls the gauge and now i need to send for repair. ANY SUGGESTIONS ? thanks. BILL Maybe Captainglen would sell you the one he removed. It sounds like it was working correctly although not the correct part for his plane.
Guest Posted September 7, 2016 Report Posted September 7, 2016 23 hours ago, DrBill said: M20Doc was right. Today we went out to replace pump and I said lets verify problem first. So I started it up and sure enough c 45psi. My A&P walked around and said no smoke, should be smoking at that pressure so we drove around the a/p for a while and back to hangar shut it down. DUH 15 PSI at shutdown. So he grabs a couple of wrenches and dives under the panel.. "WHATS IT NOW" he yells, "15 " I say. "Disconnected" he says. SO saves us a ton of work, he pulls the gauge and now i need to send for repair. ANY SUGGESTIONS ? thanks. BILL Try Keystone Instruments in PA. They do a bunch of classic instruments. Clarence
Brandontwalker Posted September 8, 2016 Report Posted September 8, 2016 M20Doc was right. Today we went out to replace pump and I said lets verify problem first. So I started it up and sure enough c 45psi. My A&P walked around and said no smoke, should be smoking at that pressure so we drove around the a/p for a while and back to hangar shut it down. DUH 15 PSI at shutdown. So he grabs a couple of wrenches and dives under the panel.. "WHATS IT NOW" he yells, "15 " I say. "Disconnected" he says. SO saves us a ton of work, he pulls the gauge and now i need to send for repair. ANY SUGGESTIONS ? thanks. BILL I have one for sale if interested. Make an offer. Sent from my iPhone using Tapatalk
Yetti Posted September 8, 2016 Report Posted September 8, 2016 On 8/14/2016 at 4:54 AM, M20Doc said: and hammer out a new data plate to "correct" the part number. Or just bend the needle on the gauge to a more pleasing value. Clarence Is that why my father gave me all those number and letter punch sets... snicker :-)
DrBill Posted September 8, 2016 Author Report Posted September 8, 2016 I'm having the original one fixed for $200 at Century Instruments where the flight school at my airport has theirs done. I would have made an offer for Brandons but for some reason I did not get notified of new posts on this topic. I did look in the classifieds for one before he posted. I wanted to go to triple tree on sat and I could have put his in by then. BUMMER. Thanks for all the replies. Bill
