I don't have my parts manual handy,does anyone have the part number for the wing fuel drains. I have one that just started leaking so I thought I would put an order into Spruce and have one waiting when I GOT home.
Thanks,
Ps. I am a new 68 M20g owner.
FB
I think there are two different kinds. One that is flush with the skin and the other drops down a bit that looks like a bolt with a hole in the middle. One picks up lower than the other. Jose was talking about the lower one can pick up contaminates easier.
Always good to have a spare.
Don't over torque...
Take the time to have a fire extinguisher near by...
Things your mom would remind you to do...(aka good ideas...)
Gloves are good, but the last time I changed I wanted to be a good boy and ware gloves... I had more fuel in the glove than on the ground. My hand itched the rest of the day. Not using them next time. It evaporates faster than it soaks in I think. Just tie a hand towel around your wrist. Fuel in the arm pit really hurts. Lol.
-Matt
I put in the 'Saf-Air' type as the Cutis type need replacing. They should have one that works for you. If I have an issue after that, I change the O-ring on the saf-air valve. I just consider the small amount of fuel that drains as a good flushing.
I had a leaky sump last year. It turned out to be debris in the valve holding it open just enough for a slow seep. Exercising the valve quick about 10 times dislodged the debris and I haven't had a leak since.
Try this before replacing the drain - it may save you time and money. I do keep a spare with me in my toolbag/parts in the plane - just in case.
A quick procedure at the hospital and you won't need gloves anymore..........oops wrong type of glove.
