ncdmtb Posted March 18, 2015 Report Posted March 18, 2015 On Friday there is a solar eclipse in Germany. I may flying a 2hr cross country during that time. Any concerns I should have? Anything particular to watch out for/be aware of? Sent from my iPad using Tapatalk Quote
Marauder Posted March 18, 2015 Report Posted March 18, 2015 On Friday there is a solar eclipse in Germany. I may flying a 2hr cross country during that time. Any concerns I should have? Anything particular to watch out for/be aware of? Sent from my iPad using Tapatalk I thought there was supposed to be some sort of solar flare as well. If this is the case, make sure you are wearing SPF 300 sunscreen I'm not sure an eclipse will do anything other than darken the skies a bit and maybe thinking you are flying at dusk or night for a little bit. Quote
Yetti Posted March 18, 2015 Report Posted March 18, 2015 The EMP will take out every integrated circuit that has not been hardened. The good news is your engine will keep running due to the 1950s technology. Quote
Marauder Posted March 18, 2015 Report Posted March 18, 2015 The EMP will take out every integrated circuit that has not been hardened. The good news is your engine will keep running due to the 1950s technology. LOL! Actually I think magnetos have been around a lot longer than that. Quote
mpg Posted March 19, 2015 Report Posted March 19, 2015 Wowwie!! did that,, 1980's, piper cherrokee, 4 folks, full fuel... took off into IMC, oooops, climed without clearence to 10,000 ft to clear on top. watched the event, took pictures, called center and confessed, begged for help. finally ran dry within sight of an airport, but out of gliding distance. impossible landing in a field, with cows, behind a piano factory! stall horn sounding softly as i turn over the building to align with the field. I call this flying the horn! dont look at the sun! welders mask glass is all you need... ps lost my ticket for 6 months,,, but only because i admitted taking off int IMC!! So dont talk to the faa. Quote
ArtVandelay Posted March 19, 2015 Report Posted March 19, 2015 Pencil me in for August 21st, 2017...total solar eclipse will traverse the mid section of the USA Quote
carusoam Posted March 19, 2015 Report Posted March 19, 2015 Spring in Dallas. Dark at lunch time is a tornado, thunderstorm and hail warning... Best regards, -a- Quote
1964-M20E Posted March 21, 2015 Report Posted March 21, 2015 Your only worry is if you are flying the Solar Eclipse then you would be a glider. Quote
cnoe Posted March 21, 2015 Report Posted March 21, 2015 Caught this partial eclipse on my iPhone in late 2012. Wish I'd had a better camera on board. Post pics from your flight if you have them. Cnoe Quote
