Guys I have a 1977 Mooney 201 with inline vacuum filter.  It is about 5/8 diameter and about 6 inches long and goes inside a aluminum housing.  I replaced it last year, but can't remember the part number or where I bought it.  I know they have been difficult to find in the past.
Can anyone help.
Thanks
  • 4 months later...
TexAir is out of stock and I discussed this with Rapco this year at Sun N Fun and they have stopped production.
Does anyone have any inventory left.
Or is there a retro fit to eliminate this type of filter.
Looking forward to your feedback.
thanks
That's a filter in front of the firewall. The bellanca filter I got from aeroparts&supply. Spruce don't carry them anymore.
  • 7 years later...
I have a 1978 Mooney M20J with a KFC200 autopilot and HSI.  One long filter supplies both the HSI and AI.  Neither the Mooney parts book or maintenance manual describe this configuration, so the filter may be the obsolete Rapco filter mentioned in this post.  Has anyone found a replacement or authorized modification.  I've searched for info, but so far haven't found an answer.1230101325_VacuumFilter.thumb.JPG.9d15c9f6e6e1af7d89a2be3f98a7c439.JPG
Welcome aboard sfowler…
Looks like a few Mooneys used different air filters over time…
Or possibly something got added along the way…
Our best parts specialist is Dan at Lasar…
He is really good at knowing what parts are supposed to be there… and often has them on the shelf…
Lasar is an MSC in Ca…
The lowest cost method is to find the proper parts manual for your plane and look it up….
Best route… If you are unsure of the part being the right one… Start with Dan….
Pp thoughts only…
It is pretty well known that Brittain uses FRAM gas filters for their vacuum filters.   I think I checked the microns and they are same as most vacuum filters.   Fram GA 12    71yloSjH80L._AC_SL1500_.jpg
Back in the days when everyone smoked, those things would get nasty.
Now that most don’t, and in aircraft that fly only 100 hours a year or less, one questions replacing them every year.
Thanks for alll the comments.  After reviewing some other forums it appears the filter in my plane is a “51A5 filter” and its use is related to my KFC200 autopilot install. Correction to my previous comment, the filter only supplies the AI, the HSI is electric only.
PT20J, you state the 1J7-1 filter is used “according to the IPC” . . . what does IPC stand for and do you know if an STC approval is available for a modification?
IPC is the Mooney Illustrated Parts Catalog. If the part is listed there, it is an approved part by Mooney.
