Endre Holen Posted November 1, 2025 Report Posted November 1, 2025 First time doing the annual on a M20F. The gear doors have some play in the down position. Looks like it is coming from the bearing in the rod ends holding the doors. Is there anything to do with that or normal?
N201MKTurbo Posted November 1, 2025 Report Posted November 1, 2025 You can try shortening the rear rod so the front rod is pushing and the rear rod is pulling. This should tighten them up. Make sure to swing them and make sure they close properly.
Hank Posted November 1, 2025 Report Posted November 1, 2025 Be careful adjusting gear doors. My new IA tweaked my nose gear door because he "didn't like how it closed." On pickup, the gear thumped and perked the yoke, so I went to see Joey Cole and he told me I was lucky that the gear came down instead of jamming. That was the only time that IA touched my plane, but he may have seen me pass overhead a few times since then. Leave Mooney-specific tasks to Mooney specialists.
PT20J Posted November 1, 2025 Report Posted November 1, 2025 Sounds like the rod ends are worn out probably from lack of lube. I’d replace the worn parts and keep them lubricated.
Endre Holen Posted November 2, 2025 Author Report Posted November 2, 2025 Yeah I think they are a little worn. Where can I order the rod ends. New to the plane so trying to figure out who has parts
PT20J Posted November 2, 2025 Report Posted November 2, 2025 Aircraft Spruce should have them. I’ve never had much luck matching part numbers. Seems every manufacturer has their own numbering system and I’ve never found a comprehensive cross reference. I just go by style and dimensions. Maybe @EricJ or @N201MKTurbo have a better way.
Fritz1 Posted November 2, 2025 Report Posted November 2, 2025 think these are special, shafts milled flat, ordered a pair from LASAR for the Bravo a couple of months ago, they had them in stock, could not find them anywhere else
PT20J Posted November 2, 2025 Report Posted November 2, 2025 You'll have to look at the IPC for your airplane. The IPC for my J calls out Mooney part numbers for the two main gear door links. The links appear to be a female rod end welded to a tube that is threaded for a male rod end at the other end to provide length adjustment. If yours is the same and most of the play is in the male rod end, it would be a simple matter to buy a standard rod end to replace it. If there is play in the welded end, you could either buy the Mooney parts through LASAR, or it would be fairly simple to have one fabricated using the original as a model to create an owner produced part. You'd have to check to see which way is most cost effective.
MikeOH Posted November 3, 2025 Report Posted November 3, 2025 What is the appropriate lubricant for the rod ends? Yes, I'm a bit lazy so I haven't looked at the MM but, IIRC, you still need to 'convert' some of those specified lubricants to presently available product. Is Tri-Flow ok? LPS? Or?
PT20J Posted November 3, 2025 Report Posted November 3, 2025 45 minutes ago, MikeOH said: What is the appropriate lubricant for the rod ends? Yes, I'm a bit lazy so I haven't looked at the MM but, IIRC, you still need to 'convert' some of those specified lubricants to presently available product. Is Tri-Flow ok? LPS? Or? I once asked RBC and they responded MIL-PRF-81322 grease. Kind of hard to apply to rod ends without zerk fittings. My M20J SMM says Tri-Flow and that's what I use. It is less oily that LPS-2 and should attract less dirt. 1
00-Negative Posted November 3, 2025 Report Posted November 3, 2025 Crap! I switched about a year ago and started putting LPS everywhere. I think it was something I read on MS that made me switch. And LPS-2 smells better! -David
N201MKTurbo Posted November 3, 2025 Report Posted November 3, 2025 50 minutes ago, 00-Negative said: Crap! I switched about a year ago and started putting LPS everywhere. I think it was something I read on MS that made me switch. And LPS-2 smells better! -David Using either is way better than using nothing. 2
