In future it's time to change my front tire and inner tube.
Front tire: Goodyear Flight Custom III Tire - 5.00-5 6 Ply
Tube: Goodyear Tube 5.00-5 Butyl Tube Tr 67A (1) B 302-013-400
Question:
Should I order inner tube with straight or 90 degree valve?
I believe you will want 90 degrees for the front tire tube, and 70 degrees for the mains.
2 hours ago, Pinecone said:
Most people seem to recommend the Michelin Air Stop tubes.
This part # 092-308-0 ?
Looks like I got this one from Aircraft Spruce about two years ago, no problems since:
06-05000 GOODYEAR PREM 5.00X5 TUBE W/ 90 DEG
I bought two so I have a spare which is still sitting on the shelf in my hangar. If you wait until it goes flat and need it fixed that day, you get whatever brand and quality the shop has sitting on the shelf, which may or may not be what you want.
