Matthew P Posted April 6, 2025 Report Posted April 6, 2025 Just wondering if anyone has installed the CC3251 Snap-Vent from Univar? We had them in the UH-60 and they were great, would assume they would be a Minor Modification to install since they are not PMA'd, can't beat the price ($35 a pair) and it would provide a vent for the right side for significantly less than replacing the side window with a vent. https://www.univair.com/miscellaneous/view-all/cc3251-large-snap-vent-pair/?srsltid=AfmBOory-7mOq4H-1wi8dzSGK6iDVHjGhhM49alZCFYrN2vl19fgkGny
cliffy Posted April 6, 2025 Report Posted April 6, 2025 You might find them very noisy all the time in flight Try opening the left side vent window and see how noisy it is. Also the left vent ha a speed restriction for some reason Does this vent system have any restriction? Just questions to ponder before installation Unintended consequences
Matthew P Posted April 6, 2025 Author Report Posted April 6, 2025 12 minutes ago, cliffy said: You might find them very noisy all the time in flight Try opening the left side vent window and see how noisy it is. Also the left vent ha a speed restriction for some reason Does this vent system have any restriction? Just questions to ponder before installation Unintended consequences Thanks, they are standard on the UH-60 Blackhawk which I flew for 20 years, they do have a 120kt limitation but I didn't see what thickness of material that was based on as I believe we had 1/4" door windows on the UH-60..Was thinking more for airflow during taxi, etc. If it's no louder than the left side, that would be fine as with the DC -1X it isn't bad....I appreciate your time, definitely something to consider.
Schllc Posted April 6, 2025 Report Posted April 6, 2025 This is much cheaper and easier. On my plane, I trimmed the arm off and remove it when not in use. The amount of air it beings in is more than you would think. I don’t even usually open the door during taxi. No use in flight, but is a great solution. https://www.mypilotstore.com/MyPilotStore/sep/13637?utm_source=bing&utm_medium=cpc&utm_campaign=bing-shopping&msclkid=0a7ed2384c381b47bf73b5caaf18288e 1
Matthew P Posted April 7, 2025 Author Report Posted April 7, 2025 5 hours ago, Schllc said: This is much cheaper and easier. On my plane, I trimmed the arm off and remove it when not in use. The amount of air it beings in is more than you would think. I don’t even usually open the door during taxi. No use in flight, but is a great solution. https://www.mypilotstore.com/MyPilotStore/sep/13637?utm_source=bing&utm_medium=cpc&utm_campaign=bing-shopping&msclkid=0a7ed2384c381b47bf73b5caaf18288e Only cheaper and easier if you have a window that already has the cutout, my window doesn't, I do however have this scoop on the left side window.
Schllc Posted April 7, 2025 Report Posted April 7, 2025 Oh, I missed that you wanted it for the copilot side. I always found opening the door and the scoop to be more than adequate. I seldom open the door with the scoop now. Even during the summer. the window in the door is pretty simple to change and an owner can do that. None of the side windows, except the windshield), are terribly complicated to change the window itself isnt that expensive either. guess you have nothing to lose by putting that into your window to see how it works. If i doesn’t work you can change it with a new one that has a vent.
Matthew P Posted April 7, 2025 Author Report Posted April 7, 2025 5 minutes ago, Schllc said: Oh, I missed that you wanted it for the copilot side. I always found opening the door and the scoop to be more than adequate. I seldom open the door with the scoop now. Even during the summer. the window in the door is pretty simple to change and an owner can do that. None of the side windows, except the windshield), are terribly complicated to change the window itself isnt that expensive either. guess you have nothing to lose by putting that into your window to see how it works. If i doesn’t work you can change it with a new one that has a vent. Looking for a cheaper option for my wife/passenger, with the age of the windows, if I replace one, I'll replace them all and a $36.00 solution is more preferable than a $600 new copilot window with the vent Eventually I'll replace all of the windows before it goes into paint, but until then just looking for something that works
Scooter Posted April 9, 2025 Report Posted April 9, 2025 Had those in a 210 in Texas. Only air we got. They work great. No speed restriction as far as I know. Up at altitude and during the winter would shut them down. Only drawback was cutting the windows. Have to be very careful not to crack the window.
