First Thread! Oil Temp and winterization
Awesome! I just got a new 252/Encore conversion and now we have our own K model thread!  I’ve had mine for about a month and flew it from Tennessee to Washington State in January to bring it home!  Really lucked out with the weather and it was clear the whole way!
Im still getting use to it, but mostly running it at 65% power lean of peak and she seems really fast!
One question I’ve had is about my oil temp.  Has anyone with a K used a winterization cover over the cooler (or tape)?  My engine runs very cool (the oat has been cold for sure but not Canada cold) and the oil temp doesn’t show more than ~125.  Chts are upper 200s.  @kortopates suggested it’s likely an indication issue - probe or wiring which I agree with.  However, I was wondering if anyone has used the winterization stuff though and what change they saw? Today I cruised at 10k, 65%, -10c and saw oil temp of 110 which seems impossible.  It also seems like the probe is directly behind the oil cooler and difficult to access.
I asked the moderators if they could give us an late Christmas present with our own M20K specific forum.
Hope it will be filled with lots of useful information for M20K owners.
I also have low indicated oil temps, and also got the advice from Paul to check the probe/ground at instruments since he claims it's a common issue with low indicated oil temps on M20K.
Just left my M20K for my first annual, and we'll see if we can find a good way to see if my probe is reading correctly or what else it could be.
Before I start to use aluminium tape on the Oil Cooler.
I also looked at some Youtube videos of M20K 252 that had low oil temps.
Will check if they just started up the engine, or if they were cruising for longer period.
I have the stock analog gauges installed.
My oil temp also reads low, usually in the 140's. I've never blocked the oil cooler. When it's very cold outside, I run with the cowl flaps fully closed which helps keep the oil temp up.
I read somewhere on here that if it's indicating 140 at the probe, it's still likely hot enough to vaporize moisture elsewhere in the engine, so not to worry. But I'm just repeating something I read on the internet there.
You're running a lower power setting than I usually do - I go closer to 75%. Nothing wrong with your setting but you might try running more power for a while and see what it does to your oil temp. I think I'd be concerned at 109 degrees. The turbocharger needs 100 degrees minimum to function properly, according to its documentation, and you may be getting too close to that.
Except the title says 231 only.  So we 252 owners (and Encore) are not welcome it seems. :D
I have a 231 with low oil temps, 150-160 in the winter.  I have started using a winterization plan with some aluminum tape on the oil cooler.  It brings the oil up to about 170.
I have an aluminum plate that covers 50% of the oil cooler that I have used in the winter and the temp gets to 180 on my JPI EDM-900. This has worked well on my 252, 262 and Encore.
Before I cover oil cooler to get higher temps, I want to make sure that I have correct reading on my oil temp gauge.
Sure I fly with 62-65% LOP but I expect higher oil temp.
CHT and Oil pressure is all good.
How does it attach to the oil cooler? Do you tape it in place? A picture would be great if you have one.
5 minutes ago, Steve Dawson said:
I have a cover that I put over mine during the winter and get 180-190 f. Hopefully the internal engine temps will be above the boiling point to try and stop any condensation created.
You don't have ro get it to boiling to drive out the water. The vapor pressure of the water increases with temperature. Boiling is just the temperature where the vapor pressure exceeds the ambient pressure above the liquid. Even if it is 10 degrees below boiling, it is vaporizing the water. And if you are at 10000 feet, the boiling point is at 193.6 F.
  • Thanks 2
