orhepxo Posted June 20, 2024 Report Posted June 20, 2024 Hello, I will be installing a Surefly on my M20C and am working on planning the installation. For anyone who has installed one, where did you pick up the manifold pressure and what fittings did you use? The instructions recommend picking it up on the #4 cylinder. However, I am tempted to install a splitter prior to the valve for my standby vacuum system. Thanks.
47U Posted June 20, 2024 Report Posted June 20, 2024 17 minutes ago, orhepxo said: For anyone who has installed one, where did you pick up the manifold pressure and what fittings did you use? I installed a T-bulkhead fitting where the manifold pressure penetrates the firewall. I made up a Stratoflex 193-2 hose with AN fitting to connect to the T and ran it along the firewall to the left mag. I can dig up the pn of the T-fitting if you’re interested… 1
