as a result of water contamination, the fuel purging efforts, resulted in the electric F. Boost pump to not function.  the AMP meter showed a draw, pump was not turning. found small metallic rectangle thin (1/2 x 1/4 inch approx) lodged in pump section, jammed impellers. am still unable to ID source of item.  any clues
It has been a while since I disassembled a Dukes pump, but it is hard to imagine how something that big got in there. The fuel tanks have screens on the pickups. Most of the hoses and passages are about 1/4 nice ID.
You don’t say which plane you have either. That makes it harder to guess.
Expand
His name is M20C69 which I would assume means he has a 69 C model.  But I could be wrong.
Expand
Looks like you’ve got a UFO in your pump…
yes, it is a 1969 Mooney Ranger. 180 hp. i agree, seems impossible for the item to be in pump impeller, but that's what we found. replaced pump because could not ID source of item.. was concerned that selector was the origin, but also seems impossible due to screen and item itself.
Expand
Can you post a picture?  You sure it’s not an impeller blade itself?
I DO HAVE PICTURES OF ITEM ON CELL PHN but don't know how to post on the net.  the piece is about twice the size of pump impellers that were all intact.
Expand
Just log into mooneyspace on your phone and attach the photos in the "choose files" on the paperclip within each post.  It is not difficult to upload a photo.
An image of the
Expand
So open up the thread in whatever browser you use on your phone. Then select “add files” at the bottom of the post. Then select the image you wish to up load.
