Wilfred Posted February 27, 2024 Report Posted February 27, 2024 I am new to this Forum, sold my Diamond DA42 last month and I am looking into Mooney's now as probably my next bird. First of all I am confused about the different models. Is there somewhere a list of types/models/modifications etc.? I am looking into the newer ones. My mission are mostly cross-country flights in Europe. Flying mostly alone. For flights with familiy my plan is to rent (DA62). Specs would be: 150+ knots Turbo FIKI Modern Avionics Any recommendation is welcome...
slowflyin Posted February 27, 2024 Report Posted February 27, 2024 The mid body K models are turbo, and many have had modern avionics installed but I'm not sure about FIKI. The Bravo, M20M, is turbocharged and available with FIKI. Again, many have nice, modern avionics. As #Brandt stated, the Acclaims are the newest, available with FIKI, and are the fastest. 1
ArtVandelay Posted February 27, 2024 Report Posted February 27, 2024 Then you want an Acclaim. Or any turbo model that’s been upgraded, even the K 231 can do 150+ knots.
Fly Boomer Posted February 27, 2024 Report Posted February 27, 2024 4 hours ago, Wilfred said: I am new to this Forum, sold my Diamond DA42 last month and I am looking into Mooney's now as probably my next bird. First of all I am confused about the different models. Is there somewhere a list of types/models/modifications etc.? I am looking into the newer ones. My mission are mostly cross-country flights in Europe. Flying mostly alone. For flights with familiy my plan is to rent (DA62). Specs would be: 150+ knots Turbo FIKI Modern Avionics Any recommendation is welcome... Most of the Mooney models can do 150 knots. The real filters on your search are the other three. As far as I know, the only factory turbocharged Mooneys are: M20K (TCM TSIO-360) 231 252 Encore M20M (Lyc TIO-540) M20TN (TCM TSIO-550) M20V (TCM TSIO-550) There are a few aftermarket turbochargers. Someone else will fill in the FIKI info. EDIT: Further search reveals that the first FIKI in the list above was the Encore, but there were so few, it is probably not a contender.
Fritz1 Posted February 27, 2024 Report Posted February 27, 2024 There are FIKI Acclaims, Bravos and Encores, the Acclaim is the latest and fastest, Continental engine, best cowl, best propeller, Bravo Lycoming engine, sodium cooled exhaust valves, oil cooled exhaust valve guides, Encore last made in 98, small bore conti, best overall airframe engine balance, they each have their pros and cons, Conti versus Lyc semi religious question like mercedes versus Beemer or Chevy versus Ford, think at least 80% of all birds are us registered
exM20K Posted February 27, 2024 Report Posted February 27, 2024 The only FIKI-eligible Mooneys are Encore (M20K Mid body Continental TSIO 360 175KTS, 12GPH, 75G fuel) Bravo (M20M Long body, Lycoming TIO 540, 190 KTS, 20ish GPH, 89G fuel) Ovation (M20R Long body, Continental IO 550, 175 KTS, 13ish GPH, 89G fuel) Acclaim (M20TN Long body, Continental TSIO 550, 210 KTS, 16-17GPH, 100G fuel) All are solid choices. I own an Acclaim and think a FIKI Encore is the best plane Mooney ever made. -dan
Pinecone Posted February 27, 2024 Report Posted February 27, 2024 Are you sure that FIKI cannot be installed on other models? Those are the ones that were available with FIKI from the factory. FYI, Encore is 175 knots on about 10 GPH. At least my 252 that is converted to Encore specs. To the OP, the list in Wikipedia of the models is pretty good.
toto Posted February 28, 2024 Report Posted February 28, 2024 45 minutes ago, Pinecone said: Are you sure that FIKI cannot be installed on other models? Those are the ones that were available with FIKI from the factory. FYI, Encore is 175 knots on about 10 GPH. At least my 252 that is converted to Encore specs. To the OP, the list in Wikipedia of the models is pretty good. You can retrofit a K, M, R, S, or TN with FIKI https://www.cav-systems.com/wordpress/wp-content/uploads/2019/11/TKS-Mooney-M20-FIKI-Specification-2019-2.pdf
exM20K Posted February 28, 2024 Report Posted February 28, 2024 (edited) 1 hour ago, Pinecone said: Are you sure that FIKI cannot be installed on other models? Those are the ones that were available with FIKI from the factory. FYI, Encore is 175 knots on about 10 GPH. At least my 252 that is converted to Encore specs. To the OP, the list in Wikipedia of the models is pretty good. Yes, those are the only FIKI-Eligible models. Among other things, a 28V electric system is a requirement. Dunno if the late “J” models wer 14 or 24, but AFAIK, they are ineligible for FIKI. -dan edit…. 28V 252’s are eligible for FIKI, but that plane would have a very low useful load. Edited February 28, 2024 by exM20K
exM20K Posted February 28, 2024 Report Posted February 28, 2024 (edited) 32 minutes ago, toto said: You can retrofit a K, M, R, S, or TN with FIKI https://www.cav-systems.com/wordpress/wp-content/uploads/2019/11/TKS-Mooney-M20-FIKI-Specification-2019-2.pdf Only the 252 and Encore, not the 231. That 14V system was working pretty hard on mine. It’s probably better, now, with advanced avionics and LED lights. -dan Edited February 28, 2024 by exM20K
toto Posted February 28, 2024 Report Posted February 28, 2024 1 hour ago, exM20K said: Dunno if the late “J” models wer 14 or 24, but AFAIK, they are ineligible for FIKI. Late J’s are 28 - mine is 28 1
PilotX Posted February 28, 2024 Report Posted February 28, 2024 5 hours ago, exM20K said: The only FIKI-eligible Mooneys are Encore (M20K Mid body Continental TSIO 360 175KTS, 12GPH, 75G fuel) Bravo (M20M Long body, Lycoming TIO 540, 190 KTS, 20ish GPH, 89G fuel) Ovation (M20R Long body, Continental IO 550, 175 KTS, 13ish GPH, 89G fuel) Acclaim (M20TN Long body, Continental TSIO 550, 210 KTS, 16-17GPH, 100G fuel) All are solid choices. I own an Acclaim and think a FIKI Encore is the best plane Mooney ever made. -dan Bravo (M20M Long body, Lycoming TIO 540, 190 KTS, 20ish GPH, 89G fuel) Also Bravo (M20M Long body, Lycoming TIO 540, 170 KTS, 14.5 GPH, 118G fuel)
Pinecone Posted February 28, 2024 Report Posted February 28, 2024 16 hours ago, exM20K said: Yes, those are the only FIKI-Eligible models. Among other things, a 28V electric system is a requirement. Dunno if the late “J” models wer 14 or 24, but AFAIK, they are ineligible for FIKI. -dan edit…. 28V 252’s are eligible for FIKI, but that plane would have a very low useful load. OK. Encore upgrade adds 230 pound GW increase.
hais Posted March 2, 2024 Report Posted March 2, 2024 On 2/27/2024 at 6:44 AM, Wilfred said: I am new to this Forum, sold my Diamond DA42 last month and I am looking into Mooney's now as probably my next bird. First of all I am confused about the different models. Is there somewhere a list of types/models/modifications etc.? I am looking into the newer ones. My mission are mostly cross-country flights in Europe. Flying mostly alone. For flights with familiy my plan is to rent (DA62). Specs would be: 150+ knots Turbo FIKI Modern Avionics Any recommendation is welcome... Curious why you consider switching, aren't those Austros perfect for Europe? 1
