jezzie Posted November 19, 2023 Report Posted November 19, 2023 I have fuel weeping in my left wing. It's time for a complete strip and reseal on my 77J. I own a salvage wing from a 78J that has bladders. Is it worth trying to move from one to the other? I am on a waiting list for fixing the weeping tanks. I expect my first call would be to the STC holder to see if the STC is transferrable? Any thoughts from the pros?? Quote
1980Mooney Posted November 19, 2023 Report Posted November 19, 2023 (edited) 52 minutes ago, jezzie said: I have fuel weeping in my left wing. It's time for a complete strip and reseal on my 77J. I own a salvage wing from a 78J that has bladders. Is it worth trying to move from one to the other? I am on a waiting list for fixing the weeping tanks. I expect my first call would be to the STC holder to see if the STC is transferrable? Any thoughts from the pros?? An STC is assigned to a specific airframe serial number. As long as the STC is still supported (which it is - Griggs/O&N) then you need the consent of the STC Holder (Griggs/O&N) in order to transfer it to a new airframe/serial number. I have a hunch that they won't do it for liability reasons. Griggs Aircraft Refinishing | Mooney bladders KNR, Inc., wrote a review of bladder application/installation in Mooney's back in 2009. They said it took 55-60 manhours to install the latest 64 gallon 8 bag (4/wing) installation. (includes cutting additional hole for an access panel in each wing in order to instal the 4th bag). If your salvage bags are the 54 gallon 6 bag (3/wing) system then the installation would be 45 hours. However you need to add more hours to remove the bags from the salvage wing. 200910 Ribs Wet or Dry? (knr-inc.com) There was a topic here on MS pirepping the installation. That topic had plenty of pictures of the job in process but sadly they are gone with the switch to the current server/host. If you Google the subject and select "images" some of the pictures remain on Google The last thing is how do you know the condition of the bladder?. Also I don't know how they plumb the separate bags together inside the wing - possible damage on removal? If your salvage bladders are the 6 bag (54 gallon) system you can buy 2 add on bladders to get up to the full 64 gallon "8 bag system". It sounds like that costs about another $3,000 and 15 manhours. They have to cut another access hole in each wing. Installing a new bladder system with a 7 year warranty is one thing - it has plenty of positives. Installing a salvage bladder system - more man hours than a new system, unknown condition and most likely reduced life. - I see a lot of labor expense with questionable life/quality - The only "positive" is the free used bags. - and I am not sure that is a positive. Edited November 19, 2023 by 1980Mooney Quote
