M20F Posted August 6, 2023 Report Posted August 6, 2023 What size is the nut on a Tempest filter? I can’t find the right impact socket for my air gun to tighten mine up.
Utah20Gflyer Posted August 6, 2023 Report Posted August 6, 2023 My plane doesn’t have enough room to use an air driven impact so I use a 6 foot breaker bar to make sure the engine filter can’t be removed by a normal mortal using normal tools. 4
SKI Posted August 6, 2023 Report Posted August 6, 2023 I just tighten mine up till I see the filter housing start to deform. I've never had one come loose yet. 3
cliffy Posted August 6, 2023 Report Posted August 6, 2023 Make it tight enough and you don't need safety wire Also two gaskets are better than one 4
MB65E Posted August 6, 2023 Report Posted August 6, 2023 Robinson Heli’s don’t use lock wire! Just saying! -Matt
MikeOH Posted August 6, 2023 Report Posted August 6, 2023 34 minutes ago, MB65E said: Robinson Heli’s don’t use lock wire! Just saying! -Matt Is that 'cause they don't vibrate as much as a plane?
MikeOH Posted August 6, 2023 Report Posted August 6, 2023 Another tip: hand tight, then 3 or 4 spot welds and you don't even need a wrench 1 2
