My KAS297B altitude preselect died.  It is p/n 065-0065-00. I am replacing it with a slightly newer p/n 065-0065-01.  I’ve read that a “-00” can be replaced with a “-01” with harness/connector pin change. Does anyone know how to make, or what is that pin change?
thanks,
Dave Ketcham
N252YB, 252/Encore
Dave, I found a SB that says that the -01 is an approved replacement for a -00.  As far as I can see the -01 was to make it compatible with a KEA346 altimeter.  BendixKing was in the habit of installing 'blank pins' in connectors to make sure you could not plug the wrong device in.
Send me an email.
Aerodon
supercub180@gmail.com
Thanks Aerodon,  FYI I have plugged in the KAS297B … -01 into the existing connector. It powers up but only shows dashes across the screen. I need to find out what that pin change is.
Thanks to another lead, the answer to installing the KAS296B p/n 065-0065-01 into an existing KAS296B p/n 065-0065-00 panel is Bendix/King SB286 which states that pin # 28 must be grounded if you have KEA 130A encoding altimeter, which I do.  I will ground the pin and report back.  Currently I only get dashes across the screen.
King KAS297B Install SB 286.pdf
