goalstop Posted February 19, 2023 Report Posted February 19, 2023 1964 M20E Volts were fluctuating from 14.5-15.1 while engine was operating. Led to nasty dimming of the lights on a 1-2 second interval Didn’t work: re-soldering transistor in dimmer panel, replacing corroded master contacter, replacing master switch Did work: cleaning contacts on voltage regulator ground & power wires Thought I’d leave this here for the next guy Check those contacts before doing expensive stuff!! 4 1 Quote
