Healthpilot Posted February 13, 2023 Report Posted February 13, 2023 Outside temperature 40 degrees F. This happens only for the first 3 to 5 min. I pulled the engine data. EGT on one and three are slow to climb. Could this be an issue with one of the sparkplugs on cylinder one and three? Quote
Brandt Posted February 13, 2023 Report Posted February 13, 2023 1 hour ago, Healthpilot said: Outside temperature 40 degrees F. This happens only for the first 3 to 5 min. I pulled the engine data. EGT on one and three are slow to climb. Could this be an issue with one of the sparkplugs on cylinder one and three? https://www.aopa.org/news-and-media/all-news/2020/july/pilot/savvy-maintance-valves 1 Quote
Ibra Posted February 13, 2023 Report Posted February 13, 2023 (edited) Does it get there quickly (EGT1) if you lean aggressively after startup ? Worth checking Cyl1 valves Edited February 13, 2023 by Ibra Quote
Healthpilot Posted February 13, 2023 Author Report Posted February 13, 2023 2 hours ago, Ibra said: Does it get there quickly (EGT1) if you lean aggressively after startup ? Worth checking Cyl1 valves Yes i did. If I lean aggressively the engine dies on me. Quote
Fly Boomer Posted February 13, 2023 Report Posted February 13, 2023 4 hours ago, Healthpilot said: Could this be an issue with one of the sparkplugs on cylinder one and three? @kortopates is one of our most knowledgeable members on topics like this. If he has time to look at it, you will almost certainly get an answer. I'm still learning how to read these things, but if there is no heat, it seems to me that either there is not enough fuel, or the ignition system is not setting the fuel on fire on every compression stroke. Sometimes these big-bore Continentals like a few taps on the primer/boost pump immediately after start -- have you tried that? Also, I would probably pre-heat at 40 degrees. Quote
PT20J Posted February 14, 2023 Report Posted February 14, 2023 Preheat is never a bad idea, but only affects starting. After a few seconds, the combustion chambers warm enough to vaporize the fuel well. Cylinders have two spark plugs. When only one fires, combustion progresses more slowly so the exhaust gasses leaving the cylinder are hotter and EGT rises. A rough running engine for several minutes after a cold start with low EGT and low CHT on specific cylinders could indicate a sticky valve. It’s more common in Lycomings, but can happen in any engine. Skip 2 Quote
Healthpilot Posted February 14, 2023 Author Report Posted February 14, 2023 38 minutes ago, Fly Boomer said: @kortopates is one of our most knowledgeable members on topics like this. If he has time to look at it, you will almost certainly get an answer. I'm still learning how to read these things, but if there is no heat, it seems to me that either there is not enough fuel, or the ignition system is not setting the fuel on fire on every compression stroke. Sometimes these big-bore Continentals like a few taps on the primer/boost pump immediately after start -- have you tried that? Also, I would probably pre-heat at 40 degrees. Yes I have tried boost pump no joy. I will check valves with borescope at annual. Although I thought big bore Continentals did not have this issue. Cylinders have less than 200 hours on them since top overhaul. I will also try pre-heat. Quote
Healthpilot Posted February 14, 2023 Author Report Posted February 14, 2023 4 hours ago, Brandt said: https://www.aopa.org/news-and-media/all-news/2020/july/pilot/savvy-maintance-valves Thank you I will borescope cylinder 1 and 3 at annual coming up. 1 Quote
Fly Boomer Posted February 14, 2023 Report Posted February 14, 2023 7 minutes ago, Healthpilot said: Yes I have tried boost pump no joy. I will check valves with borescope at annual. Although I thought big bore Continentals did not have this issue. Cylinders have less than 200 hours on them since top overhaul. I will also try pre-heat. If, as @PT20J (Skip) suggests, valves are suspect, I wouldn't wait for annual inspection to get a borescope in there. It's not invasive, it's cheap, and it's quick. Also, I wouldn't allow the "200 hours since top" to influence my diagnostic steps -- we all want a big expense like that to go the distance, but sometimes it doesn't turn out that way. I wish you the best of luck. 1 Quote
PT20J Posted February 14, 2023 Report Posted February 14, 2023 If you suspect valves, I would definitely work to eliminate that sooner rather than later. If a valve sticks hard closed, something has to give and it will bend the pushrod. Then, you'll know for sure! But it's not good if it happens in flight. Quote
dzeleski Posted February 14, 2023 Report Posted February 14, 2023 This is what a sticking valve looks like and sounds like. Based on that EGT graph you have a sticking valve. As said above this is something that needs to be looked at today, not in a few weeks or in a few months. Quote
Healthpilot Posted February 14, 2023 Author Report Posted February 14, 2023 No plans to fly before checking. Annual is scheduled for week after next. This is the first time it happens. Does anyone know a good A&P in the Seattle area expert on Continental big bore engines that has access to a decent borescope? if not I will purchase one and give it to my mechanic. They seem to be quite cheap now. Is this one ok or not good enough? 5mm Ultra Fine Dual Lens Endoscope Camera, Hiacinto 5inch IPS 1080P Digital Inspection Camera with IP68 Waterproof, Automotive Scope Camera with 7 LED Lights, 16.5FT Semi-Rigid Cable, 32GB Card: Amazon.com: Industrial & Scientific Quote
rickseeman Posted February 14, 2023 Report Posted February 14, 2023 I would buy the borescope like Mike Busch uses. It's cheap and I like it. Can't remember the name. Sorry Quote
rickseeman Posted February 14, 2023 Report Posted February 14, 2023 I think it's a Vividia VA-400 Quote
Fly Boomer Posted February 14, 2023 Report Posted February 14, 2023 52 minutes ago, Healthpilot said: No plans to fly before checking. Annual is scheduled for week after next. This is the first time it happens. Does anyone know a good A&P in the Seattle area expert on Continental big bore engines that has access to a decent borescope? if not I will purchase one and give it to my mechanic. They seem to be quite cheap now. Is this one ok or not good enough? 5mm Ultra Fine Dual Lens Endoscope Camera, Hiacinto 5inch IPS 1080P Digital Inspection Camera with IP68 Waterproof, Automotive Scope Camera with 7 LED Lights, 16.5FT Semi-Rigid Cable, 32GB Card: Amazon.com: Industrial & Scientific As @rickseeman suggested above, get the Vividia recommended by Mike Busch: https://www.aopa.org/news-and-media/all-news/2017/may/pilot/savvy-maintenance-borescope Also, be sure you are getting the latest version. They keep improving it, but they don't change he model number. I don't think there is a way to tell by examination either -- you just have to buy from a supplier that has lots of turnover, like Spruce. Quote
ilovecornfields Posted February 14, 2023 Report Posted February 14, 2023 17 hours ago, Fly Boomer said: @kortopates is one of our most knowledgeable members on topics like this. If he has time to look at it, you will almost certainly get an answer And if you sign up for Savvy Analysis , he will almost certainly look at it! 3 Quote
rickseeman Posted February 14, 2023 Report Posted February 14, 2023 I would feel better if anything Mike Busch says about cylinders would be chiseled in granite for preservation. To the OP: You started a gasoline engine without a choke on a cold day. (Without EFI.) It's not supposed to start idling and run perfectly smooth. After a little bit, it gets some heat in it and runs fine. I say this is perfectly normal and there's nothing wrong with your engine. Quote
PT20J Posted February 14, 2023 Report Posted February 14, 2023 12 minutes ago, rickseeman said: I would feel better if anything Mike Busch says about cylinders would be chiseled in granite for preservation. To the OP: You started a gasoline engine without a choke on a cold day. (Without EFI.) It's not supposed to start idling and run perfectly smooth. After a little bit, it gets some heat in it and runs fine. I say this is perfectly normal and there's nothing wrong with your engine. 3 minutes rough at 40 deg F doesn't sound normal to me. 1 Quote
rickseeman Posted February 14, 2023 Report Posted February 14, 2023 Maybe, but it is an Ovation. Which sure does seem like a cold natured engine. 1 Quote
Guest Posted February 14, 2023 Report Posted February 14, 2023 4 hours ago, rickseeman said: Maybe, but it is an Ovation. Which sure does seem like a cold natured engine. Then there’s something wrong with it. Quote
Guest Posted February 14, 2023 Report Posted February 14, 2023 The engine monitor data is already telling us which cylinder is unhappy. Unless borescope technology has changed recently, I don’t know how it will tell us the valve is sticking. Always ready to learn more. Quote
Healthpilot Posted February 15, 2023 Author Report Posted February 15, 2023 2 hours ago, M20Doc said: The engine monitor data is already telling us which cylinder is unhappy. Unless borescope technology has changed recently, I don’t know how it will tell us the valve is sticking. Always ready to learn more. Great question. This is all I could find: Anatomy of a Valve Failure - AOPA Quote
Pinecone Posted February 15, 2023 Report Posted February 15, 2023 Here is the borescope that Mike Busch uses: https://www.amazon.com/gp/product/B01MQPC6U1/ref=ppx_yo_dt_b_asin_title_o06_s01?ie=UTF8&psc=1 Last year, they changed the unit to a higher resolution camera. But they did not change the model number or anything. I ordered mine in July 2022, and the one I got is the higher resolution. BTW, a borescope is not going to show you a sticking valve or why. That occurs inside the valve guide. One more thought, if your A&P does not have a borescope, I would be thinking about finding an A&P that has joined the 21st Century. 2 Quote
Healthpilot Posted February 16, 2023 Author Report Posted February 16, 2023 11 hours ago, Pinecone said: Here is the borescope that Mike Busch uses: https://www.amazon.com/gp/product/B01MQPC6U1/ref=ppx_yo_dt_b_asin_title_o06_s01?ie=UTF8&psc=1 Last year, they changed the unit to a higher resolution camera. But they did not change the model number or anything. I ordered mine in July 2022, and the one I got is the higher resolution. BTW, a borescope is not going to show you a sticking valve or why. That occurs inside the valve guide. One more thought, if your A&P does not have a borescope, I would be thinking about finding an A&P that has joined the 21st Century. If borescope cannot diagnose, what do you guys propose as a way to diagnose the potential sticking valve problem? Just to be clear this may be just me be overzealous since my A&P thinks this is just oil fouling, and the cylinder is just slow to come up to temp and burns off the oil the problem simply goes away. He is recommending monitoring and flying since this has never happened before. He thinks that it is VERY unlikely that this is a valve issue. Quote
Healthpilot Posted February 16, 2023 Author Report Posted February 16, 2023 On 2/14/2023 at 7:37 AM, dzeleski said: This is what a sticking valve looks like and sounds like. Based on that EGT graph you have a sticking valve. As said above this is something that needs to be looked at today, not in a few weeks or in a few months. Interesting. When you increase RPM in the video roughness seems to decrease. In my case it doesn't. If I increase RPM in the first 3 minutes roughness increrases. Quote
