Recently had a boost pump regulator go out on me and just replaced the blown diode and transistor to get it back up and going.  I'd like to sanity check the voltages coming out of the regulator though... what is considered normal from an output perspective?  It is all adjustable via a trimmer potentiometer, just wondering where to start.
Kinser,
This is where it is good to mention your skills as an electrical technician / A&P… etc…
Plenty of people that want to help you…
They just need to know you are not a pilot fixing his own plane… :)
Let us know how it goes…
These things fail every couple of decades…
eliminating the Lo fuel output.
let’s invite @M20Doc to the conversation… (boost pump regulator question m20r)
Just looking at the circuit, it doesn't look like a voltage regulator, it looks like some kind of timer. If that's the case, it should be 28 volts coming out. I would replace the relay.
The same guy must have designed the other little boxes like the LED bar graph indicators and the flap relay board. All have the same look and feel.
My understanding is that the regulator is for low-boost. In high boost the pump gets full 28V and in low-boost the pump gets a lower regulated voltage. So the question is, what is the proper voltage for low boost? Somebody would probably have to measure it.
What is odd about the picture is I don't see any typical larger power handling transistors with heat sinks that you would typically use in this application.
Larry
The start-up transition on Lo must be a killer…
If the pump doesn’t start right away… there is probably a ton of heat generated instead.
PP thoughts only…
The procedure is in the engine fuel set up section of the manual.  You adjust the pump to set a specific output fuel pressure.
10 hours ago, carusoam said:
Kinser,
Oh don't worry, there is a rebuilt unit from an approved shop on the way for the actual aircraft.  I just couldn't see a board that looks this straightforward and not try to resolve it.
10 hours ago, N201MKTurbo said:
I would look at the boost pump and see what voltage it is rated at and adjust the regulator accordingly.
The pump itself is rated at 28v, which it gets when the high boost rocker switch is activated. This regulator is just used for low boost, hence the need for the lower voltage to achieve a lower output.
Oh it's definitely a regulator.  The transistors are on the backside. ;)
That all being said, that's a pretty old school single sided hand routed PCB for 2000. They must have had the old guy do it...
It kind of looks like what I would make for science projects in high school. And not just the board itself, but also the box containing it. It looks just like what radio shack used to sell as "project boxes".
Larry
You hit the nail on the head with regard to the low vs high boost aspect. As for the transistors, they're mounted on the backside of the board and use the metal case itself for heat dissipation. That design does make things cumbersome though, because the transistor cannot ground to the case, despite mounting to it. So they couldn't use normal thermal paste for the backside of the transistor and instead has to use fiberglass based thermal pads and plastic screw insulation shims and mounts.  It seems... sketchy.
Ah, so no set voltage, just whatever is necessary to achieve to desired pressure. Thank you!
  • 1 year later...
58 minutes ago, Dominik_B said:
Hi kinser, i got a similar problem... Can you tell me what type of transistor you used as a replacement? thanks Dominik
Welcome to MooneySpace!  It's been almost six months since kinser was here, so he may have moved on.  That said, this forum doesn't work like email -- if you want to notify another poster that you have responded, you need to quote part of their post by selecting some of their text and then clicking the "Quote" pop-up, OR by inserting their name with an "at sign" followed immediately (no space) with their screen name.  This use of the "at sign" will display a pop-up box with suggested names you can select from.  Good luck.
Hey @Dominik_B -- there are two components there, the rectifier (2 legs) and the bipolar transistor (3 legs).  I'll link to the ones I used below.  And just in case someone is reading this years in the future and the reseller has removed their product pages, the rectifier is MUR1540G and the transistor is 2N6668 PBFREE.
https://www.mouser.com/ProductDetail/onsemi/mur1540g/?qs=Gev%2bmEvV0iZq6LchZ03NqA%3D%3D&countrycode=US&currencycode=USD
https://www.mouser.com/ProductDetail/Central-Semiconductor/2N6668-PBFREE?qs=l7cgNqFNU1ijRYXR1DLWNQ%3D%3D&countrycode=US&currencycode=USD
