Mcstealth Posted March 4, 2022 Report Posted March 4, 2022 Thank you in advance, Another rookie question. How can you tell if a 430 is Waas or not? Is there an easy way? David Quote
toto Posted March 4, 2022 Report Posted March 4, 2022 If I remember correctly, the non-WAAS unit uses an 8mb data card, but the WAAS unit uses 16mb. You might just be able to pop out the card to see. 1 Quote
toto Posted March 4, 2022 Report Posted March 4, 2022 Btw - if it was sold from the factory as WAAS, it will say "430W" right on the face of the unit. The units that were upgraded are the ones that you can't tell at a glance. 1 Quote
carusoam Posted March 4, 2022 Report Posted March 4, 2022 When setting up the flight plan…. If you can’t find any WAAS based approaches… This might be a sign it is non-W…. We can always ask @Alan Fox he can sense the W and non-W as he approaches them… PP logic only, I don’t have a Garmin navigator yet… Best regards, -a- 1 Quote
pkellercfii Posted March 4, 2022 Report Posted March 4, 2022 The only certain way to tell a 430 from a 430W is from the splash screen that is displayed on startup. —Paul Keller 4 Quote
toto Posted March 4, 2022 Report Posted March 4, 2022 40 minutes ago, carusoam said: When setting up the flight plan…. If you can’t find any WAAS based approaches… 37 minutes ago, pkellercfii said: The only certain way to tell a 430 from a 430W is from the splash screen that is displayed on startup. Well, geez - yeah, these work if you can turn it on I thought we were talking about a radio in a box or something .. 1 1 Quote
LANCECASPER Posted March 4, 2022 Report Posted March 4, 2022 Blurry picture, but this is what the splash screen should look like on a WAAS. 1 1 Quote
Alan Fox Posted March 5, 2022 Report Posted March 5, 2022 I just look at the antenna , If it is a GA56 , it aint WAAS 1 2 Quote
carusoam Posted March 5, 2022 Report Posted March 5, 2022 5 minutes ago, Alan Fox said: I just look at the antenna , If it is a GA56 , it aint WAAS This is why Alan is the go to guy for pre-flown avionics… He doesn’t even have to get near the box to know what it is or isn’t… -a- 1 Quote
Mcstealth Posted March 6, 2022 Author Report Posted March 6, 2022 On 3/4/2022 at 7:33 PM, Alan Fox said: I just look at the antenna , If it is a GA56 , it aint WAAS Is this the correct one? Quote
Mcstealth Posted March 6, 2022 Author Report Posted March 6, 2022 On 3/4/2022 at 8:22 AM, LANCECASPER said: Blurry picture, but this is what the splash screen should look like on a WAAS. Definitely does not have that screen. Quote
Rick Junkin Posted March 6, 2022 Report Posted March 6, 2022 On 3/3/2022 at 10:48 PM, toto said: If I remember correctly, the non-WAAS unit uses an 8mb data card, but the WAAS unit uses 16mb. You might just be able to pop out the card to see. The 8mb non-WAAS card has a green label, the 16mb card has an orange label. They are not interchangeable. Cheers, Rick Quote
Alan Fox Posted March 6, 2022 Report Posted March 6, 2022 7 hours ago, Mcstealth said: Is this the correct one? That is a GA56 , not legal for a WAAS reciever 2 1 Quote
