Seth Posted August 19, 2009 Report Posted August 19, 2009 During the post about ground backfiring, I realized that I know of a sterotype of Mooney's out there to not make it to TBO. Let's see if we can debunk this fact. 1. What kind of Mooney do you have 2 What is your current engine time - not any problems, issues, top overhauls, etc . . . 3. If you have replaced/overhauled an engine, did you make it to TBO? What was the time on the engine? Let's keep this to Mooney Aircraft for now, but if you feel that you have to share another aircraft, feel free. Also, please make sure to list if your engine is not a 2000 TBO (it will be assumed 2000). I'll start 1. 1967 M20F 2. 320 hours - ground backfiring/popping, clogged fuel injector - easily fixed. 3. The former owner replaced the engine due to a cracked casing - I do not have the time as its in the logs which are at the shop. Quote
Parker_Woodruff Posted August 19, 2009 Report Posted August 19, 2009 1. 1990 Mooney M20J-AT 2 Approximately 1400 SMOH, 350 since top with cermanil cylinders several years ago. Bought the plane in February. All compressions are mid-high 70s. 3. My airplane is on its fourth engine, IIRC. It has generally gotten about 1900 hours before overhaul, but that was all by Embry Riddle Quote
wmrunyon Posted August 19, 2009 Report Posted August 19, 2009 1. M20M 1991 2. Current engine time 950 hours, Lyc reman; only engine problem has been with the exahaust system, expensive to repair or replace. 3. The 1st engine made it to 1850 hrs. Quote
eaglebkh Posted August 19, 2009 Report Posted August 19, 2009 1. 1964 M20E 2. Current engine (engine #2) is at 900 hrs with a new #4 cylinder at 600 hrs 3. 1st engine made it to 500 hrs (replaced in 1970 with factory reman) So, if you can do the math - my engine is nearly 40 years old with 900 hrs. I know, that's only 23 hours per year on average, but it is running really smoothly with high compressions and slightly higher-than-normal oil burn. This winter I am looking at OH, though, because my mechanic isn't going to sign off on the annual again with a 40-year-old engine and I agree. Quote
KJATCt Posted August 19, 2009 Report Posted August 19, 2009 1. 1965 M20E 2. 1918 hrs Original jugs, compression all in the mid 70s with +/- 3 spread. I fully intend to go past 2000 hrs. Quote
Jeev Posted August 19, 2009 Report Posted August 19, 2009 1978 M20J 1500 SFOH in 1993 Lowest comp found on annual insp last month was 76/80, runs strong with average oil burn, plan on running it as long as she is healthy. Quote
Cruiser Posted August 19, 2009 Report Posted August 19, 2009 1984 M20J 6097.0 hours on the original engine. replaced in 2008. 85 hrs. on FREM Quote
jrjaks Posted August 19, 2009 Report Posted August 19, 2009 Present Mooney: 1982 M20J 500 SMOH Crankshaft AD-replaced at 300 SMOH, (new pistons, rings, etc.) Premature Cam wear - replaced by Lycoming 450 SMOH, (new pistons, rings, roller tappets). Running great. Previous Mooney: 1963 M20C Sold with 2800 SMOH, running great when sold. Quote
N9937c Posted August 20, 2009 Report Posted August 20, 2009 m20k 1981 1954 sreman never had a cylinder off just checked comp. low 73/80 high 78/80. 1 qt in~ 20 hours Is intercooled and spoiler equipted larry Quote
jlunseth Posted August 20, 2009 Report Posted August 20, 2009 If you are getting compressions in the 70's on the Continental engine you might want to have a Mooney shop check the compressions. I don't know the technical part. I think most shops just catch the momentary highest pressure on each cylinder, while the correct way is to move the prop around and see what pressure the cylinder will actually hold. Measuring the pressures correctly will usually get you into the 50 and 60's on the Continental. Quote
N207LS Posted August 20, 2009 Report Posted August 20, 2009 1. 1968 M20G (Lycoming O-360) 2. 650 SMOH (2004) done at Devine Aircraft Engine, TX, Former owner did MOH and replaced all four cylinders with new Millennium Cylinders. www.superiorairparts.com/millenniumCylinders.asp. He also added the Powerflow Exhaust at that time. www.PowerflowSystems.com. And the K&N air filter mod. This was the second overhaul on this engine (3600 AF TT), the first was a field overhaul done in 1986 at ~ 1700 hours. 3. Compression from last annual was 74-75-75-78. Currently burns about 1 quart every 8 hours of flight time. No engine issues since I puchased the plane in 2005 with 40 SMOH. Have only had to replace the starter since and went to the new Sky Tech. Aaron Quote
Seth Posted August 20, 2009 Author Report Posted August 20, 2009 1984 M20J 6097.0 hours on the original engine. replaced in 2008. 85 hrs. on FREM ---------- Did you really have 6000 hours on the original engine? How many overhauls? How many problems? Quote
FlyDave Posted August 20, 2009 Report Posted August 20, 2009 Quote: Seth 1984 M20J 6097.0 hours on the original engine. replaced in 2008. 85 hrs. on FREM ---------- Did you really have 6000 hours on the original engine? How many overhauls? How many problems? Quote
Guest Anonymous Posted August 20, 2009 Report Posted August 20, 2009 Quote: N207LS 1. 1968 M20G (Lycoming O-360) 2. 650 SMOH (2004) done at Devine Aircraft Engine, TX, Former owner did MOH and replaced all four cylinders with new Millennium Cylinders. www.superiorairparts.com/millenniumCylinders.asp. He also added the Powerflow Exhaust at that time. www.PowerflowSystems.com. And the K&N air filter mod. This was the second overhaul on this engine (3600 AF TT), the first was a field overhaul done in 1986 at ~ 1700 hours. 3. Compression from last annual was 74-75-75-78. Currently burns about 1 quart every 8 hours of flight time. No engine issues since I puchased the plane in 2005 with 40 SMOH. Have only had to replace the starter since and went to the new Sky Tech. Aaron Quote
Cruiser Posted August 20, 2009 Report Posted August 20, 2009 Quote: Seth 1984 M20J 6097.0 hours on the original engine. replaced in 2008. 85 hrs. on FREM ---------- Did you really have 6000 hours on the original engine? How many overhauls? How many problems? Quote
N207LS Posted August 21, 2009 Report Posted August 21, 2009 RFB, I keep my oil level at 6-7 qts. Eight means one on the belly and seven for the engine,so I add one every time it gets to 6. Minimizes fresh oil on belly. I put 7 in at the oil change as well. This seems to work for me. I have considered the M20, but haven't pulled the trigger yet. Let me know if you do it and your results. Aaron Quote
Parker_Woodruff Posted August 23, 2009 Report Posted August 23, 2009 Quote: JimR 1) 1978 M20J - 10,090 hours TTAF 2) 2855 hours on FNEW (Engine #1) 2894 hours on FRMN (Engine #2) 2816 hours on FRMN (Engine #3) 1525 hours currently on FRMN (Engine #4) 3) My plane was used by a radio station in the San Francisco Bay area for the first decade or so of it's life, which is where it racked up almost all of it's time. Since all of the engines were factory remans, I don't have logs for them, but Tom Rouch of Top Gun Avation maintained it during those years, and he has told me that all of the engines made it beyond TBO without serious problems. The current engine has also had no engine problems during my tenure and according to the logs. Quote
MooneyPilot231 Posted August 24, 2009 Report Posted August 24, 2009 Glad to see someone post about the Continental compression numbers. I bought my plane with less than 200 hrs on a FRME and the compressions were right at 70. My A&P was the one that told me that was perfectly normal for a Continental, especially a turbo charged Continental. (require much bigger ring gaps) It is almost impossible to get my engine within 100 deg. of where it actually runs during a ground run up with the top cowl off so there is no way to get an accurate test reading really. Again, having owned a very high end race engine shop and having built engines making over 1900 h.p., I would like to point out that what aviation calls a compression test is in fact a leak down test. In truth, it almost useless as a diagnostic tool to determine the condition of an engine. An engine with good numbers can burn oil like a bandit and another with compression readings in the mid 60's could be perfectly healthy. I know most people refuse to believe this, but it is a fact!My plane's first engine, the GB model, made 1600 with no top overhaul. Current engine has 400 hrs.... Quote
skyking Posted September 5, 2009 Report Posted September 5, 2009 First engine made it to 1850 hours but it was not looked after very well and the aircraft sat for a long time without being used. Current engine only has 200 hours and the prop, hub, spinner etc is only a month old. russ Quote
mooniac58 Posted September 5, 2009 Report Posted September 5, 2009 1987 M20J - 1890 SMOH 550 STOH Compressions range 74-77 on all cylinders, I do oil analysis at every oil change which is 25-35 hours and it is always good. I don't feel any need to overhaul at this time although the IO-390 does tempt one a little Quote
lahso Posted September 6, 2009 Report Posted September 6, 2009 1. 1966 M20C. 2 175 hrs. 3. Did not make it to TBO. 1800 hrs were on the engine at the time I decided to do a major overhaul. Previous owners did not fly very much (it didn't sit for long periods, but they put only a few hours a month on it). Quote
Ned Gravel Posted September 6, 2009 Report Posted September 6, 2009 Mine made it to 1951 hours before leaking oil at one of the lower bolts on #2 caused us to check for binding on the shaft. Turns out there was a 7" crack in the case from that bolt going aft and down. Major overhaul time. I do not believe it was looked after very well before I bought it at 1640 hours. Now it is 25-30 hours for an oil change and I have a JPI on board to keep an eye on things. Manage the temps and use it a lot. That is what my AME (A&P for y'all) tells me. Quote
HopePilot Posted October 7, 2009 Report Posted October 7, 2009 One of the planes I'm looking at was rebuilt in 1990 and has about 700 hours on it. How long past Lycoming's 12 year TBO recommendation do you guys feel safe with? Quote
Cruiser Posted October 8, 2009 Report Posted October 8, 2009 check the NTSB database. Search for accidents that were caused by engines too old for continued flight into normal conditions. (kidding of course) Quote
JBrown Posted March 24, 2010 Report Posted March 24, 2010 2000 M20S Eagle, 310hp Currently 2189.7, prop strike and tear down in 2004 (previous owners...). Two new cylinders (one ECI, one Conti) so far. Currently keeping it on a tight leash with the EDM, and the mechanic here at SouthWest Texas Aviation says we should get another 200-300 hours no problem. I am having the sagging engine mounts replaced next week though. Quote
