65C_flier Posted September 30, 2021 Report Posted September 30, 2021 (edited) Is there is supposed to be a drain hole in the bottom of the air induction box as shown in the picture (78J, but I assume it would apply to most models)? I guess it makes sense to drain water if it got in there somehow, but I would have thought the engine would always be sucking a bit of unfiltered air through there. We plan to incorporate SI M20-93 to remove the ram air, but we can't seem to get a kit. Looks easy enough to make the kit. Does anyone happen to know the thickness of thr blanking plate? I'm guessing around 0.032". Thanks. Edited September 30, 2021 by 65C_flier add pic Quote
ArtVandelay Posted September 30, 2021 Report Posted September 30, 2021 With the amount of air the engine takes in, that small hole would only let a minuscule of unfiltered air in, and obviously nothing bigger than the hole.My AP took care of removing the ram air without the kit so don’t know details, but don’t forget to repair the baffling as well: 1 Quote
N201MKTurbo Posted September 30, 2021 Report Posted September 30, 2021 The drain hole is important, If your plane is sitting outside in a driving rain storm, your intake will fill full of water without it. It happened to me recently. I ended up making a cowl plug for the left side so the rain can't get to the air filter. My turbo system doesn't have a drain hole in its intake so the turbo filled full of water. The plane wouldn't start, I pulled the plugs and they were all wet. I dried them, pulled the intake pipe from the turbo, drained the water and blew it dry with compressed air. Went and flew it for about 1/2 hour. It worked fine. Quote
Will.iam Posted October 6, 2021 Report Posted October 6, 2021 On 9/30/2021 at 1:01 PM, N201MKTurbo said: The drain hole is important, If your plane is sitting outside in a driving rain storm, your intake will fill full of water without it. It happened to me recently. I ended up making a cowl plug for the left side so the rain can't get to the air filter. My turbo system doesn't have a drain hole in its intake so the turbo filled full of water. The plane wouldn't start, I pulled the plugs and they were all wet. I dried them, pulled the intake pipe from the turbo, drained the water and blew it dry with compressed air. Went and flew it for about 1/2 hour. It worked fine. Do you have a picture of your homemade cowl plug? Where did you get the materials? Quote
EricJ Posted October 6, 2021 Report Posted October 6, 2021 5 minutes ago, Will.iam said: Do you have a picture of your homemade cowl plug? Where did you get the materials? FWIW, the one's Bruce's makes are quite good and not terribly expensive. I use a set when travelling if it's going to be parked on the ramp for a while. https://aircraftcovers.com/M201 Quote
Will.iam Posted October 6, 2021 Report Posted October 6, 2021 1 minute ago, EricJ said: FWIW, the one's Bruce's makes are quite good and not terribly expensive. I use a set when travelling if it's going to be parked on the ramp for a while. https://aircraftcovers.com/M201 Thanks but that is for the air scoops in front and i want a plug for my turbo naca scoop on the right side of the cowl that goes to my turbo air-filter housing as i could see how that could fill up with water with a hard rain. Quote
N201MKTurbo Posted October 6, 2021 Report Posted October 6, 2021 27 minutes ago, Will.iam said: Thanks but that is for the air scoops in front and i want a plug for my turbo naca scoop on the right side of the cowl that goes to my turbo air-filter housing as i could see how that could fill up with water with a hard rain. My plane is a 201 with a turbo. The cowl plugs that Eric mentioned are essentially what I made. I made mine out of 2" polyethylene foam. Quote
Will.iam Posted October 6, 2021 Report Posted October 6, 2021 Humm i guess my search continues maybe mooney went to that Naca side scoop to address this issue although i think it was more for eliminating icing than water. Since my plane stays in a hanger i would be bummed if i was at an outstation overnight with heavy rains and got stranded. I wish my canopy cover went over more of the cowl to include the scoop but it doesn’t. I’ll have to look next time the cowl is off at the bottom of the filter housing to see if there is a drain hole. Has any 252 owners had this problem come up? Quote
blaine beaven Posted October 6, 2021 Report Posted October 6, 2021 I can confirm my 78J has a drain hole as in your picture. After my last annual I had to pull the cowls for something and got really excited about all the oil in the inside middle of the bottom cowl; I then recalled that shortly after the annual I had been flying through some heavy rain. Sure enough a lot of the oil that was on the new air filter ended up coming out the drain hole and dripped onto the cowl. Something I had yet to experience but made me more conscious of that drain hole. Sent from my iPhone using Tapatalk Quote
