A64Pilot Posted September 2, 2021 Report Posted September 2, 2021 On 8/31/2021 at 7:25 PM, jetdriven said: I let the filter sit upside-down for a couple days and drain out, then I cut it remove the filter media and if you really want to see what's going on wash it in a half a quart of mineral spirits and then put a magnet under the cup and pour off the liquid Yes washing can be very effective and if you really want to be anal, filter it through a coffee filter. GE would have us do that and send them the coffee filter. I used to think filter magnets were hokum until I saw them collect ultra fine metal particles that were so fine they felt like grease
NicoN Posted September 2, 2021 Author Report Posted September 2, 2021 On 9/1/2021 at 12:09 AM, M20Doc said: There is an oil suction screen on the back left corner of the accessory housing, and the pressure oil filter on the centre of the accessory housing. During oil change pre fill the filter with oil before installing it. Clarence These 2 plugs labeled "11". What are they for? There is a little oil sweating
N231BN Posted September 2, 2021 Report Posted September 2, 2021 These 2 plugs labeled "11". What are they for? There is a little oil sweatingThey are basically cavity drains and serve no purpose normally. Uses a regular crush gasket.
Guest Posted September 2, 2021 Report Posted September 2, 2021 7 hours ago, NicoN said: These 2 plugs labeled "11". What are they for? There is a little oil sweating They’re just drain plugs, they require MS35769-11 or AN900-10 gaskets. Clarence
